Cars & Trucks Logo
Greg Warren Posted on Jun 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I clear a service emissions message on a 2005 Mercury Mariner with a 3.0L engine. I have performed the required maintenance procedures at both 30,9000090's and 60,000miles. Still have message.
Jeff Armer
Level 3:
  • Mercury Master 15,575 Answers
  • Posted on Jun 15, 2016
Jeff Armer
Mercury Master
Level 3:
Answers
15575
Questions
Helped
7111957
Points
73899
Warning Messages The warning messages can interrupt the display until cleared or reset by the driver. The warning messages are either single cycle, non-resettable, or repetitive warning messages.
The single cycle warning messages display once whenever the ignition switch is turned to the ON position or a fault occurs in a system, and can be cleared by pressing the RESET button. The single cycle warning messages are:
  • liftgate ajar
  • liftgate glass ajar
  • service emission system
  • low brake fluid
  • service brake system
  • check left headlamp
  • check right headlamp
  • check left turn lamps
  • check right turn lamps
  • check left high beam
  • check right high beam
  • check brake lamps
  • check parking lamps
  • washer fluid low
  • check fuel cap
  • change oil soon
  • change oil now
  • low fuel
  • service 4x4
  • turn signal on
3 Related Answers
A
Anonymous
  • Posted on Sep 19, 2008
SOURCE: 2005 toyota camry 4cylinder
disconnect the positive battery cable for 3 min.reconnect and start it up,if light comes back on,there is a malfunction in computer system that controls your drivetrain.service engine soon light pertains to the computer,sensors,etc.this light is not for maintenance reminders!
Anonymous
  • 1861 Answers
  • Posted on Nov 17, 2008
SOURCE: Remove Oil maintenance required message on 2008 Toyota Highlander
This is the reset proceedure for a 2008 Highlander with a key-type ignition:
Turn the key ON, do not start the engine.
Look at the odometer, and verify that it displays "TRIP A". If it is on "ODO" or "Trip B", press the black stick next to the odometer to read "TRIP A".
Turn the key OFF.
Press in, and HOLD the black trip meter reset button, hold it IN.
DO not release it.
Observe the Odometer display. You will see 5 dashes, then 4, then 3, then 2, then 1 dash, and finally, 5 zeros. Then, whatever number that was displayed on "TRIP A" will be re-displayed..
Now release the black trip meter reset stick.
This completes the reset procedure, and it will be back on in 5,000 miles, to remind you of you next oil change.
Hope this helps! Thanks for choosing FixYa!
A
Anonymous
  • Posted on Nov 29, 2012
SOURCE: Service emission sys warning message on ford Mercury Mariner 4DW 2005
Injector Cleaner is not in any owners manual
It is a few onces in many gallons of gas & does nothing
Check for codes & have the car diagnosed --as with any and
all issue from the past on any vehicle
If you over fill it you can get fuel into the evap canister
1helpful
Why is the Emission system needs service indicator light on? What does it need.
The most common problem is a leak in the evap system which vents the fumes in the gas tank to the vapor canister.
Sometimes its a loose or faulty gas cap.
2006 mercury mariner won't start
Tow it to a shop- to have it diagnosed, to find
a problem, or the many problems you many have
from lack of Preventative Maintenance
Jumping any vehicle made from 1996 on, is not a good idea
& will bit you some day
Today's electronics have to be handled in the proper
why or you could ruin things
Help someone-- by jumping off from your vehicle--that's nice
Their on their way & you ruin yours
How does that work,can happen,now
what,your & your vehicle have an issue
Engine light
The engine light comes on to alert you to the fact a malfunction has occurred in the engine control system or emission system, you now must have the system tested for the fault code that is stored when the light was turned on by the computer control module.
2answers
How long is the life span of a mercury 2006 mariner 2 wheel drive?
The life span is usually about 100,000 miles. Could be more or less depending on the preventive maintenance performed.
4helpful
2answers
I want to change the amber side marker light on a 2005 Mercury Mariner but the manuel says to take it to a dealer to have it done. Is it that hard to do myself? Thanks
Side Lamp/Front Turn Signal Lamp Bulb
Removal and Installation
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
  1. Remove the 2 fender splash shield bolts.
  1. Remove the 3 fender splash shield pin-type retainers.
  1. Remove the screw and position the fender splash shield aside.
  1. Remove the front turn lamp bulb holder from the lamp assembly.
  1. Remove the front turn lamp bulb.
  1. To install, reverse the removal procedure.
2helpful
2answers
How I reset the 'check engine light' on 2009 mercury mariner?
There are 2 ways to do this. The first is to disconnect the battery and let it sit for 60 seconds. The other is to use a scan tool to clear the codes. The light will come back if you haven't corrected the problem though. I would recommend going to an autozone and getting them to scan and find the code for you. You may need to replace a component in your emissions system. I hope this helps.
2answers
How to do I reset the maintenance service light on my 2007 Chevy Trail Blazer
there is no light for emissions testing on this vehicle. there is a ses light that can come on, indicationg a problem with the engine or transmission electronic system. this will require a scan tool to pull trouble codes. there is another light called oil life monitoring that needs to be reset after oil changes, which I suspect is what you are seeing. here is a picture of the light and the instructions for resetting.,
The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where you change your oil prior to a CHANGE OIL SOON message being turned on, reset the system.
After changing the engine oil, the system must be reset as follows:
  1. Turn the ignition to RUN, with the engine OFF.
  2. Press the information and reset buttons on the Driver Information Center (DIC) at the same time to enter the personalization menu.
  3. Press the information button to scroll through the available personalization menu modes until the DIC display shows OIL LIFE RESET.
  4. Press and hold the reset button until the DIC display shows ACKNOWLEDGED. This will tell you the system has been reset.
  5. Turn the key to LOCK.
If the CHANGE ENGINE OIL message comes back on when you start the vehicle, the Engine Oil Life System has not reset. Repeat the reset procedure.
1helpful
2answers
Resetting check engine light after changing fuel filter on 2005 mercury mariner.
Disconnect negative terminal on Battery for 5 minutes.If this does not work take to your nearest OReillys stroe and they will reset it for you for free
9helpful
Replace alternator on 2005 mercury mariner
change alternator on a 2005 mercury mariner 2wd with a v6
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
