Question about JBL Audio Players & Recorders
Jvl subwoofer makes a loud Popping noise while
JBL subwoofer makes a loud Popping noise while "ON". Power also turns off.
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
  • 8 Answers
SOURCE: jbl 12 subwoofer
Good chance it's the power supply; a capacitor there, the large one, may have gone. These things age and when they go, there's noisy power to the amp circuit and ... well, that may be what you're hearing. You should check your audio wiring, too. That woofer could be picking up a 60Hz hum from the AC mains and amplifying it. Maybe you can try another spkr on same cables and see if hum is in your woofer or elsewhere. Good luck.
Posted on Sep 11, 2007
xX_Nem0n_Xx
  • 25 Answers
SOURCE: Subwoofer thumping when turn on
Your subwoofer is not getting enough power, or it is grounding out due to a bad connection. What is powering the subwoofer? You might want to consider buying an AC to DC power inverter and a car amplifier to power your subwoofer. You connect the AC/DC inverter to your amp the same way you would in your car (+) to (+) and (-) to (-). The only other thing you will have to do is run the remote wire to the (+) on the amp. You can buy the AC/DC inverter at radioshack for $49.99, and all you really would need is a 200watt max amplifier and that would cost you about $10-$20.00 for a cheap one.
Posted on Feb 24, 2008
SOURCE: subwoofer makes loud popping crackle intermittently
im having the exact same problem thinking it was the amp i rigged up a different driver,the amp was fine.i knew the driver wasnt gone and after some looking and testing i got it down to wire mesh(i think a dust sheild,something)inside which was slightly rubbing on the coil,it worked fine loud when it was warm but cold there was bursts of bad feed back noises.
Posted on Mar 14, 2008
SOURCE: subwoofer clicking noise
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Posted on Apr 29, 2008
How do I pair my JBL Cinema SB350 sound bar and subwoofer
This PDF should help you with anything you need related to your JVL Cinema SB350. http://fccid.net/pdf.php?id=2287143
Oct 18, 2014 | Audio Players & Recorders
I'm getting a loud "popping or clicking when i plug the sub in. also i noticed the green light comes on immediatly when the loud popping begins. the loud popping dosen't stop untill i unplug it
What's feeding it? The sub comes on automatically when it senses a signal, which seems to be what it's doing. Perhaps the loud clicking is originating at the other end of the cable.
Jan 27, 2010 | JBL PSW-D110 Speaker
Jbl 12 subwoofer loud noise
Hiya, could be the power supply or possibly the amp circuit that has gone. If there are electronic guys in your area, they should be able to sort it out relatively easily. Get a quote first, make sure it is in economical repair as well, but it can be repaired
Jul 09, 2009 | JBL PB12 Subwoofer
My JBL PowerBass PB12 makes a continued loud sound when it is on
Have you tried turning the gain down before turning it on. If that works, it might be the internal amp picking up noise somewhere. Maybe even a bad ground. Either way there are only a few things you can try before complaining to the manufacturer or replacing it. Changing its location might help and if it does might indicate RF interference. You can also try running it through a power strip, one equipped with a filter (these are fairly common). Good luck
-Dynami
Mar 29, 2009 | JBL PB12 Subwoofer
JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 10, 2009 | JBL PB10 Subwoofer
Subwoofer isn't working
If your wire connections are normal then the problem is due your woofer speaker. Its your subwoofer circuit error and must be repair thru replacing the damaged Component in the circuit
Dec 09, 2007 | JBL SCS135 System
904 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
