Question about Windchaser Horizontal Or Vertical Column Fan
I have a windchaser wch31 and am trying to disassemble it to repair the fan. The electric is going through, power light is on, cool air is being generated, but fan blade will not rotate. matt0907@hotmail.com
4 Suggested Answers
SOURCE: Cleaning the WIndchaser WCUFI tower fan
Yeah easy on the back near the handle there are two screws unscrew them next gently tug the back cover off and it will sound like it is break but it is just unclicking. And as always unplug the thing.
Posted on May 05, 2008
mohammed387
  • 1952 Answers
SOURCE: NEED A FAN BLADE FOR WINDCHASER MODEL WC163C
try this link www.amazon.com/WindChaser-High.../B000G64O5A
shopping.yahoo.com/s:Portable%20Fans:4168-Brand=WindChaser
Posted on Jun 21, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Posted on Sep 07, 2009
Testimonial: "Unbelievably fast response - off to try to fix it!"
Why is it not cooling?
compressor trying to start but not starting replace capacitors.
Aug 20, 2015 | Windchaser PACR10 Portable Air Conditioner
Cooling fan for a presario cq5621wm dont work
Central Processing Unit chips have a tendency to overheat when used for long periods of time. This is why virtually all desktop processors come installed with cooling systems that include a cooling fan. However, cooling fans are not invincible. They can burn out if they are not cleaned often and properly. To clean the fan in a Compaq Presario desktop, there is some light disassembling involved to gain access to your computer's CPU fan.
Turn off your Presario desktop and disconnect the power cord from its socket. Wait 10 to 15 minutes before you begin disassembling your computer. Attach an electro-static discharge wrist strap to your wrist and attach the wire clip to the outer casing of the desktop. This helps prevent damage to your computer caused by static electricity. Rotate the desktop so the back panel is facing you. Place the desktop on its left side. Remove the two Phillips-head thumb screws from the right side of the computer's back panel. Grasp the molded grip on the side access panel and slide the panel away from the desktop. This will reveal the interior components of your computer. Locate the cooling fan assembly attached to the back panel of your computer. Grasp the power cable extending from the fan, follow the cable to its connector on the motherboard and disconnect it from the motherboard. Locate the locking tabs on either side of the air duct assembly. Insert a small flat-head screwdriver into the notches on each tab and disengage each tab. Remove the air duct once the air duct assembly comes loose. Repeat this procedure in reverse to install the new cooling fan assembly.
This might not be your specific desktop computer it might give some insight into repair or removal
How to Properly Clean Your Desktop Cooling System & Fan http://www.youtube.com/watch?v=GgOaIJ82gFM&playnext=1&list=PLu_9NJ3Eiy2XGhZxa5wlnkxdPbrJG5hjw&feature=results_main
Feb 22, 2013 | Compaq Computers & Internet
When the fan kicks in. The unit screams
Noisy fan can be caused by a worn out fan/bearing or there may be some debris in the fan area. You can disassemble the unit to explore this. You might find debris or by wiggling the fan cage you can usually tell if its loose, the bearing is shot. Sadly, the company is out of business, and I dont see these parts being available anymore. So you really have nothing to lose by doing a little exploratory surgery.
Aug 09, 2011 | Windchaser PAC9 Air Conditioner
It stops cooling
more than likely leaked out all the freon. replace.
Jul 15, 2010 | Windchaser PACR10 Portable Air Conditioner
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
Apr 22, 2008 | Windchaser WCUFI WindColumnUltra Tower Fan
Model number not listed
That is a good question. My Model FTR184 Windchaser fan is not working either (has standby light on, and doesn't run, even when temperature setpoint is reduced to less than room temperature (in the PS - personal settings - mode), and more frustratingly, even in the FAN mode, where there is not supposed to be a Standby mode. That darned red Standby LED light just stays on no matter what mode I have fan in (though it does go off when I operate the Power on/off switch to turn everything off. So, I agree with Lease. Why isn't our fan model listed? And, of course, what is wrong with mine.
Sep 02, 2006 | Windchaser FTR163 SensorFan Stand...
Dryers Logo
51 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
