Question about Dryers
Dryer not heating up
My dryer is running but I do not feel the heat.
  • 867 Answers
Most likely heating element is fried, less likely os that one of the thermostats is faulty
Posted on Jul 17, 2009
Dryer runs takes too long too dry clothes
Start the dryer and let it run for about 5-7 minutes, do you feel any heat if you open the door? If your dryer is producing heat most likely you have a restriction/blocked vent.
Oct 01, 2014 | Kenmore Dryers
Maytag dryer model #MDG308Dawn heat not coming out of dryer dryer motor running but clothes are not drying can't feel the heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Maytag Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Our dryer stopped heating so we changed element and cutoff kit, worked for 2 loads and quit, again changed cutoff kit and worked for 15 minutes and stopped heating again, what are we not doing right?
The cutoff is there to trip if too much heat builds up around the heating element. The most common reason for this is plugged venting. But it has to do with poor air flow for sure.
- Check to make sure your lint screen is clean and nothing is fallen down the lint filter chute
- Briefly run the dryer without the vent connected and feel the air coming out the back of the dryer, it should feel like good air flow, now connect it again and feel the air where it comes out of your home, it should feel about the same strength.
- To clean the vent, you can use a long brush, a vacuum or even a leaf blower to try and clear the lint. (blow from inside out or you may make a mess inside)
Apr 23, 2010 | Kenmore 62802 Electric Dryer
Runs but is not heating up
Check your vent that comes out your house. If you are not feeling no air, it is being blocked by lint. If you are feeling air more than likely it is your heating elements.
Nov 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer too much heat, or no heat at all
your vent is plugged somewhere clear the vent you can tell if its plugged is when running the top is hot
Sep 15, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
