My brake pedal became very hard to push down and the truck slowed down the way a truck would without power brakes. Pedal doesn't go to floor, truck slowly stops. I was told it might be vacum lines to the master cylinder.
No such thing as vacuum lines to the master cylinder. You do have a vacuum line on the brake booster (power assist). When you step on the pedal do you hear a whoosing sound down by your pedal. This is a leaking Booster. Needs replacement.
When you step on the brake does the engine rpm change. This is a leaking check valve (one way air valve).
Yes replace it and beed the brakes with new fluid
I was pulling a trailer with a washing machine on it and it seem to lose power when you pushed the gas pedal down more,like it was skipping
