Question about Maytag MFI2568AE Side by Side French Door Refrigerator
New filter, water lines connected, ... no water
We recently replaced the filter, attached nessecary water connections, but when we went to get water, no water or ice? Not sure1
    Champion:
  • 363 Answers
When you made water connections did you open the valve at the water source
Posted on Jul 22, 2009
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
How to change a water filter on a Noritz tankless water heater
Turn off your incoming cold water to the tankless. (you should probably do the same with your hot water out line just in case). find the black cap that screws sideways into the cold water connection on the bottom of the unit. unscrew the black cap. the filter is supposed to be attached but it almost always comes off. grab a screw driver and stick it in the hole that the black cap was covering. angle it and drag the filter out. you may end up putting a hole in the filter this way but it doesn't matter if you are replacing the filter anyways. once you pull it out make sure you have a little rubber washer on the new filter or else transfer from the old one. the new filter should actually attach itself nicely onto the black cap so once you've removed the old one all you have to do is screw the black cap/filter combo piece back onto the cold water connection and you're done.
I suppose I should mention you will want to have a bucket under the pipes and everything because your unit will empty all the water that was in the unit out of that hole.
Apr 13, 2013 | Noritz 6.9 Gallon Residential Tankless...
Side/side frigidaire not dispensing water & no ice-replaced filter-opened up back of unit- cleaned up- water coming all the way to the frige from house main- hear regular noise like when it wants to...
your double water valve is the problem. solenoid is probably stuck(located on water valve) just replace with new one. water line is connected directly to water valve which is attached w/a couple of screws. hope this helps.
Dec 25, 2010 | Frigidaire PLHS269ZC Side by Side...
LEAKING WATER
The plastic line has cracked at the water valve. See this page item 804:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=206380&diagram_id=21040526#d21040526
It is a matter of turning off the water supply, removing the attaching nut and compression fitting then cut off the line... transfer the inner sleeve nut and brass outer compression ring to the new hose then reinstall the line onto the water valve. If it is leaking at a water filter connection the repair is the same as above.
Turn on the water supply when you finish.
Thanks for using FixYa.
Kelly
May 12, 2010 | Refrigerators
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Water dispenser slow flow after filter change
I had the same problem when switching to Pur filters. There are two curved wedges inside the end that hold the filter away from its connection. It turned out that they were just a little to short, putting the end of the filter to close to the connection, and that's all it took to restrict the water flow. I went to the hardware store and found a thin plastic washer that would add some space (it was for a faucet diverter of some kind, thinner than a dime). It added just enough space for good water flow. Another benefit was it helped stop the icemaker line from freezing. A simpler solution might be to make sure to get factory-original filters.
Apr 02, 2009 | KitchenAid KSRS25IL Side by Side...
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Water dispenser stopped working after changing filter
There is a built in system of valves on the filter connections that enable changing filters without turning off the water. IF the filters are not fully connected the valves wont open and there wont be any water flow. .
Feb 17, 2018 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Fridgidaire side by side
It may be that the filter (if you have one) may be plugged up. Some have in-line filters that need replaced occasionally, especially if you have hard water. Trace the water line and look for something that looks like this:
d931a8c.jpg There is a small connection on both ends.
Some fridges have a filter that is similiar to an oil filter and just twist in.
If the problem is not the filter, you need to check the connection that you line comes from to make sure you have water available at the source. The supply line itself may be plugged.
Oct 09, 2008 | Frigidaire GLRS264ZA Side by Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
103 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
