Question about Dell E151FP 15" Flat Panel LCD Monitor
Image go off
When i put on my computer, the screen of flat screen goes black , no image comes
I, too have this problem with the monitor going off after 2 seconds when booting. It might stay on after turning off and on repeatedly, and will stay on until the pc is rebooted. Any suggestions?? Mine is a Dell 15" LCD about 3 yrs old
JC
  • 1 more comment
  • danfrefra Dec 04, 2007
    my monitor doesnt go on
  • GUITAR DUDE Sep 30, 2008
    When I switch on the PC, the monitor (CMV) begins to flicker on and off and this goes on for about 2 - 3 min before it gets steady to start my work.
  • frustrated i Jan 31, 2009
    My DELL Flat Panel Wide Screen Monitor keeps blacking out. Sometimes every other minute, to other times after an hour or so. How can I detect the problem?
Flashlight trick works great. I can see images. Now what do I do?
Posted on Nov 12, 2008
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After they shut down on their own, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 25, 2008
    Genius:
  • 1,601 Answers
Sounds like the backlight is failing. If it is still under warranty, have the manufacturer fix it.
Posted on Nov 18, 2007
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | Computers & Internet
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Oct 14, 2008 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Monitor goes off and on
Yes your backlight is going bad! This is common with an LCD monitor! There are no guarantees with these new items! Sorry I hope that this helps! When a backlight goes bad it will generate enough light to display an image, but it will not hold that charge for very long, it varies based on the manufacturer who sells the Montior!
Nov 26, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Image go off
I have had the same problem. I've just managed to get the monitor working again by VERY QUICKLY navigating through the monitor setup menu to the 'factory reset' option and hitting reset before the screen had a chance to blink off.
The problem I had is that the monitor suddenly goes black, but will come on for five seconds if I switch it off and on with the power button.
In that five seconds, I had to...
>Hit the menu button
>then hit the '+; button once
>then hit the menu button again
>then hit the '-' button
>then hit the menu button one last time
The above brings up the menu, scrolls up off the top of the list to the last item on the list (Factory Reset), selects Factory Reset, selects 'All settings' and resets the monitor.
I don't know if this is a permanent fix, but it just worked for me and mine has been doing this intermittently for the last week.
Give it a try, it's frustrating and will take a few tries, but it can't hurt.
Oct 27, 2007 | Dell E173FP 17" LCD Monitor
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Dell E151FP 15" Flat Panel LCD Monitor Logo
214 people viewed this question
Alun Cox
