Question about Whirlpool ED5FTGX Side by Side Refrigerator
Walls of refrigerator overheating
The Walls of the refrigerator are very hot. I noticed this a couple of days ago when I opened the refrigerator and the seal around the door was hot.
Help.
dididsaythat
  • 291 Answers
SOURCE: Frame where door seals is very hot
Fan should be running when compressor and fan in refrig. is running... replace condenser fan, compressor will over heat with out fan running, and refrig. cant get rid of the heat in pulls out of freezer.
Posted on Sep 12, 2007
fridgetech
  • 473 Answers
SOURCE: Warm to Hot molding that seals the doors
Either the fan motor has gone bad or the coils under the fridge are too dirty. Both will cause a no cool situation and cause this area to become too hot. Part of the coil runs thru the cabinet in this area to prevent sweating. This is a good indication of dirty coils or a bad/weak fan motor. If your fan was noisy I would replace it before it goes out completely. This excessive heat will lead to premature compressor failure.
Posted on Nov 11, 2007
  • 1462 Answers
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
transom between fridge and freezer is usually haeted to stop condensation when you open freezer door. suspect you have no fault
Posted on Jul 14, 2008
mikedurland
  • 481 Answers
SOURCE: front metal piece that the seal goes against - between freezer and fridge
clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 23, 2008
docjohn174
  • 943 Answers
SOURCE: Seals are hot
hI iF YOUR FRIDGE AND FREEZER ARE COLD AND TEMP IS OK THEN ITS FINE oN FRIDGES THERESHEATERS THATGO AROUND THE DOOR TO KEEP THE CABINET WARM TO STOP CONDENTION SO THIS IS NORMAL THANKS FOR THE QUESTION THE APPLIANCE DOC
Posted on Sep 12, 2008
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Overheating ... the rubber edging on the doors is very hot
The rubber edges on the door are suppose to get hot.
some times the fill very hot. many people don't notice this. There is a small mullion heater plased around the doors so that the gasket will not freeze and the door will stick and not open.
Jun 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
99 Firebird still overheating after repairs and antifreeze
overheating is most likely a bad thermostat, but the coolant loss is a second big concern. Does the exhaust look like steam? You could have a cracked block and the coolant is leaking into the engine. Also check the oil for contamination.
Feb 16, 2010 | 1999 Pontiac Firebird
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Coolent leak... 96 dodge caravan
if you get an overflow through the resevior it's often times because the thermostat with stick shut causeing excess pressure. seeing is the car is not overheating this means that the trhermostat is opening but when you get that overflow it's sticking i would replace the thermostat as soon as possible to resolve this issue
Apr 26, 2009 | Dodge Intrepid Cars & Trucks
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Fridge/freezer warm, no fan, light's on
you can remove back cover feel the compressor, is it hot?? perhaps it overheate.
Feb 24, 2008 | Refrigerators
Sep 12, 2007 | Maytag MZD2752G Side by Side Refrigerator
Whirlpool ED5FTGX Side by Side Refrigerator Logo
925 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
