Question about Dryers
IF A GAS DRYE IS NOT SET FOR LPG GAS WHAT WOULD BE THE REACTION IF YOU TURN IT ON
  • Dryers Master
  • 8,220 Answers
Soot on clothes, smelly clothes.
Posted on Jul 17, 2009
Does an xh ute have the same fuel gauge for gas and petrol. When I change to gas my fuel gauge drops to empty????
Don't know the vehicle at all, but perhaps the gas (I assume you mean something like lpg) gague is sharing the same power set up, ie when switch to gas, the power or sensor wires are then redirected elsewhere, so the fuel gague drops off, till returning to petrol.
See this scenario on a couple of lpg cars here in uk. All lpg cars I've seen do not share a gague though.
May 29, 2015 | Cars & Trucks
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
Why does Oven soot up during use?
Are you on propane (LPG) or natural gas? I would guess that you are on propane, and that your oven has not been converted over to LPG correctly. The regulator needs to be set up for LPG, and the oven gas orifaces need to be tightened down, and the air valves opened up. If you don't know what these terms mean, then you need to contact a professional, because you don't want to monkey around with gas!
Aug 31, 2014 | Kitchen Ranges
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Imperial ifs 40: gas comes out of jet and the burners work fine for a moment, then the flame ignites inside the burner and makes a worbling noise every now and then popping. is this low gas...
Check your manual and make sure your burner is configured for the gas that you are using. In most cases, there is an orifice that needs to be changed for using LP, or a screw setting that needs to be changed- most new appliances ship with a "city gas" configuration ( AKA NG - Natural Gas) and need to be configured for LPG (Liquified Propane Gas). The fitting(s) that need to be changed are tagged. This is due to the pressure difference between NG and LPG. Propane (LPG) runs at a higher pressure.
You state that your fryer is LPG. If you are running it on NG ("city gas") you need to consult your manual for converting it to NG. Outside of making sure that you are set up for the right gas, you should not have to make any other adjustments. For safety reasons, gas regulator pressure adjustments are for the most part no longer possible on gas appliances.
Mar 21, 2011 | Imperial IFS40 Deep Fryer
How is liquid lpg system set up? i have a aqua star mod.125vp that i would like to install in my home, the liquid lpg. is the part im not shure about. thanks d.r.
The lpg either cylinder or gas tank must have a pressure reducing valve which sets the gas pressure to that required by the boiler.
After that valve the piping is the same as for any gas boiler.Where the pipe goes through the wall floor of similar - make sure the pipe has a sheath to protect it from gouges and or wet
The regs - Not sure about the USA but here in UK we have comply. different regs for tank or cylinder
The lpg supplier is a good source of info
Feb 16, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
Toyota 3y engine fuel system
LPG 3Y engine toyota crown comfort automatic - fuel consupmtion is 13.30litre per 100km? How can this be reduced?
Jan 08, 2010 | 2002 Toyota Camry
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
