Washer does not go on when we hit the start button
When we hit the start button the washer does not go on. sometimes it works and sometimes it does not. can you please give me some suggestions to do to fix it. my husband thinks it has something to do with the panel board?
Tks, Lisa
  • 867 Answers
From what you described, it is a control issue as your husband suggested.if it is a mechanical type with a dial, try tapping it, or openning the panel and spraying it with an electronic contact cleaner
Posted on Jul 17, 2009
What should I check if there is no water or spinning after you start the machine?
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire washer not getting any water or spinning. I see that you hit the start button and all the lights come on, and then hit the start a second time and all it does is clicks a couple of times but no water or spinning occurs. There could be a number of possibilities that can cause this to happen.
First, check to make sure that the door is completely closed. Sometimes the door seems like it is closed all the way, but it is slightly open and the locking mechanism is not catching, which could possibly be causing the clicking to happen.
Secondly, check the water hoses coming from the wall and into your washer to make sure that they are not kinked.
Lastly, it could be the motor itself. If the motor overheats, it will automatically restart after a 30 minute cool down period.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire Washing Machines
Wont start.buzzes.unplug to turn off
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Feb 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont start. I soaked a shower curtain in bleach, ran the machine to add water and then hit pause to allow the fabric to soak in the bleach before washing. I pushed the pause buttonn to continue thewash...
I would unplug the washer to reset it. if you have already hit the power button to turn the unit off and it failed to respond. Newer washer machines are like computers, and smart phones these days. you have to reboot them because they do sometimes lock up. Pull the cord for about 5 minutes and see if that resolves your issue.
Dec 03, 2013 | Maytag MAH6500 Neptune Front Loading...
While my wife was washing, the water was turned off to the washer. She hit the pause/cancel button. Now that the water is turned back on, when we hit the start button, all the lights turn off.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Jun 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer is not working
this code is for a door lock failure. it can also be a ccu problem as well. some have had luck hitting the back right corner of the machine forcefully to remedy this problem.
Jul 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer not starting
when you hit start button does your washer makes one beep and go off ? if yes i think it is your main control board need to be replace.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont start
what is the model number of the washer
Jun 10, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
