Question about Philips Audio Players & Recorders
My philips personal sound system display says: problem! connect to your computer
How do i use the philips hand held garment steamer with dual voltage
I have an older model ...while plaster
thank you
Posted on Jul 17, 2009
Blank display on the Monitor when connected to main system
if u feel the problem with you display cable then try to replace that
May 12, 2010 | Philips 107E56 17" CRT Monitor
Connecting a computer to a LX3600D Home system
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
Nvidia graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Sep 19, 2009 | Philips LX3600D System
About my portable sound system
how a do fix because show problem please connect to computer
Jan 21, 2009 | Philips GoGear ShoqBox PSS110
Pss110/5 system problem
The PSS110 is not fully compatible with Vista.
You can download the Philips Device Manager for the PSS110 from:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=SHOQBOX_SU&session=20080627080823_82.5.154.61&grp=PORTABLE_ENTERTAINMENT_GR&ctn=PSS110/05&mid=Link_Software&hlt=Link_Software
The software is not Vista compatible so you will have to run it on an XP machine.
Run the Device Manager and select the repair option. This will update the firmware and replace the system files.
Make sure the player is connected to the mains during this process.
Use the Philips Device Manager
Jun 16, 2008 | Philips PSS110/17 MP3 Player
USB and speakers not working.
Have you got..
  1. A USB cable from the computer connected to the USB input on the monitor? It needs that cable to supply USB outputs from the monitor. The monitor acts as a USB hub.
  2. The speakers on the monitor also require a cable from the soundcard on your computer to the sound input of the monitor.
May 24, 2008 | Philips 190B7CB LCD Monitor
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
HELP HELP HELP!!!!
Sounds like the firmware has corrupted. Install and run the Firmware Update software from the product CD.
Select the repair option and follow the on-screen prompts. This will re-load the firmware and should get your player working again.
Feb 20, 2008 | Philips GoGear SA178 MP3 Player
Sound cuts out every so often when using Coax Digital In
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Philips shoqbox
You have a file error: a system file may be missing or you have a format error on the SHOQBOX. To fix this problem: 1. Connect the SHOQBOX to the computer using the supplied USB cable. 2. Plug your SHOQBOX into a wall outlet with the supplied AC adapter. 3. Launch the Device Manager at Start->Programs->Philips->Philips->PSS110 (or the model number of your SHOQBOX) on your PC. * IMPORTANT: All music & content of your SHOQBOX will be erased once the factory setting is restored. 4. A dialogue box will pop up; click Restore and OK to confirm and start restoring the unit to its factory setting. 5. Follow the on-screen instructions to complete the restoration. 6. The Device Manager will close automatically once the success message is displayed. 7. Transfer a couple of songs into your SHOQBOX to confirm if the SHOQBOX has fully recovered all the files. 8. Close all opened applications and safely remove your SHOQBOX by clicking on the icon on your Windows task bar tray. 9. When prompted, ?The USB Mass Storage Device can now be safely removed from the system?, click OK and unplug your SHOQBOX. 10. Your player will display ?UPGRADING FIRMWARE?? once disconnected from the computer. 11. After firmware upgrade is complete, it will reset itself, showing the PHILIPS splash screen. 12. Press to switch on the player again.
Sep 12, 2007 | Philips ShoqBox PSS120 MP3 Player
103 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
