Question about Heavy Machinery
How do you remove the bedknife for a Vermeer 1800 turbo wood chipper? (Its really rusty) thank you
  • 708 Answers
Should be allen head screws at right angle to blade.
Posted on Nov 20, 2017
  • 83 Answers
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
Posted on Mar 31, 2009
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: VERMEER CHIPPER BC 625AI MANUAL HOW TO GET ONE
well if you ring up jhon from vermeer he wll send it out to your address.
Posted on Nov 25, 2009
SOURCE: What year is my wood
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
Posted on May 17, 2011
SOURCE: How to remove impeller assembly from chipper
The impeller is on a keyed taper on the motor. Remove the shredder blade as shown in the user manual, Screw the hex centre bolt back into the shaft leaving some slack. Using a suitable puller (I used a harmonic balancer remover) with bolts through the shredder blade bolt holes and the centre screw on the hex bolt, apply pressure and tap with hammer. The taper tends to rust a bit, so it may take while to move it, but when it comes, it comes with a rush. I suggest a smear of grease on the taper when reinstalling to limit future rusting.
Posted on Sep 20, 2012
How do you change oil in a Vermeer feed roller
I would google the unit model number for oil change instructions, since I don't have the model number I can't do it.
Dec 31, 2014 | Heavy Machinery
I have a vermeer 1600a wood chipper with a 300 6clinder ford engine. I am looking for a manual to help me do some repairs on it.
Holy cow! A bit out of my area. If it's the engine, go to FOMOCO website of course. If it's the machine, go online to the manufacturer, if they're still in business. I'm sure you've tied this, but just in case..... If they're not, get manuals online for chippers of similar size. The technology may be similar, too. Manuals for discontinued machinery are often on eBay, too. Good luck.
May 16, 2014 | Heavy Machinery
Vermeer bc625a won't start
Check the starter and solenoid.
Nov 22, 2013 | Vermeer Bc625a Wood Chipper
'07 BC1000XL Vermeer Wood Chipper, 65hp engine with turbo. turned ignition key, sounded like it wanted to turn over but wouldn't. I ran it an hour prior with no problem, turned it off to create another...
Starter Motor / Solenoid Relay not functioning. /Not Enough charge in the Battery to develop the current to turn engine over/ Knife blade jammed / Spark plugs wet. 100's of possibles. Need to Start from Key to Motor and eliminate / Verify .
Aug 23, 2010 | Garden
Vermeer A1600 wood chipper blade replacement
Go to this page to find the nearest dealer:
http://www.vermeer.com/vcom/DealerLocator/DealerListing.jsp
They do not have parts listings on line. You will have to call them.
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Garden
How do I change the belt on a Vermeer 1230A Chipper?
Here is a link to Vermeer, they should be able to assist you with a diagram or PDF manual.
www.vermeer.com
Feb 10, 2010 | Garden
I am looking for a vermeer parts/ service manual for a 1250bc wood chipper help!!!!!!!!! PLEASE
Go to Vermeer.com and put in the model number and serial number. Vermeer will send you an operaters manual, parts breakdown and repair manual for free.
Apr 10, 2009 | Garden
if you go on www.vermeer.com you can request a new manual and they will send it out to you.
Oct 13, 2008 | Heavy Machinery
Heavy Machinery Logo
501 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
