Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
Leak under scotsman under counter ice machine
  • Scotsman Master
  • 8,220 Answers
Drain tube might have fallen off the ice bin.Just a guess.
Posted on Jul 17, 2009
What metal frame filter do I need for our Scotsman cm3 ice maker?
I take it that the machine you have is a under the counter machine if so then the part number you will need is 7629143 and you can order it on line. If you post the model number of your machine then i can make sure you get the right part number. cm3 just means it has the cm3 controller in it.
Mar 09, 2015 | Kitchen Appliances - Others
I have a scotsman CM3 with aquaarmor ice machine. There is a constant trickle of water coming from each leg. Why is the happening???
Try taking off a side or back panel and see if there is frost building up. If frost is present, it could be low on refrigerant.
If there is condensation, it could be the insulation is saturated with water allowing thermal transfer to condense water out of the air.
Feb 06, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice maker not getting cold
The refrigerant charge is blown due to a leak or the compressor is bypassing discharge gas into the suction.
Jun 16, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Machine won't turn on
Check and make sure you have power at plug. if so then make sure you turn machine on. if it is a small under counter unit then the switch is behind the cover down at floor. if not then pull front cover on the ice head and push the freeze tab.
Jul 10, 2013 | Scotsman Kitchen Appliances - Others
I have a scotsman dce 33 it is 10 years old. Service man said it has a leak and is a sealed unit. I would need a whole new sealed unit. Could this be repaired by putting a valve in line, fixing the leak...
What I gather from the technicians remarks are the whole sealed unit and he leaves out the defined area of the leak. Sometimes leaks like this are really difficult to find and repair especially if the ice machine is still in use. To answer your question yes it most likely can be fixed if the leak location is found, fixed, pull another vacuum and recharged with Freon, If you have more questions I will be here to answer them for you, Sea Breeze
Nov 27, 2011 | Scotsman DCE33PA1BC 15in Built-in...
I have a CSX45A1D Scotsman under the counter ice maker. Need manual for this unit. Thanks Dennis
Hi I think your model is the csw45 if it is then you can download the manual from http://www.scotsman-ice.com/docs/uploaded/sct/manual/Csw45m.pdf
Jul 29, 2011 | Scotsman CSW451D 15" Ice Maker with 26 lb....
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Kitchen Appliances - Others Logo
188 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
