Question about Tanaka 22" Double Sided 24cc Hedge Trimmer
Will start and run 20 secs at working speed and stops .will start and run at tick over speed. will start and run at working speed with half choke,but does not like this too rich condition. New plug, clean air filter,new fuel filter. Any suggestions. had carb off and carefully cleaned components.regards h. Kinnerrsly
  • Anonymous Mar 25, 2014
    Fuel filter clean spark ate store clean will not run at high speed bogs out
  • 76 Answers
Hi
Did you change the fuel cap .
consider changing it , if the cap is old or not sealing well air comes in and causing this problem.
Posted on Jul 17, 2009
My Weed Eater FL1500LE will only run on full choke and will stop when changed to half choke or throttle is moved from fast idle to any lower speed. I have replaced both fuel lines, thoroughly cleaned the...
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Sep 22, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Runs only on half choke
Before you take it a part adjust the fuel air mixture most of these small engines are air 1 1/4 and fuel 1 turn get it to ideal just before the foot spins ( let the engine warm up good and have fresh fuel before doing these adjustments) afer a good ideal adjust the mixture for a full no bogging speed . If this does not work then start to work on the carb.
Jul 20, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
What is h and l screws for we have been moving them around to try make the saw tick over as it keep cutting out
"H" is high speed and "L" is low speed. Turn both screws in full, then unscrew them one and a half turns each. Start the saw, you may have to adjust the trottle screw to keep it running.Then adjust the "L" screw a little, in or out, with the trottle screw until you are happy with it ticking over. then adjust the "H" screw to get it to run full. You need time and patience. Stephen.
Sep 24, 2010 | Husqvarna Chain Saw 20" Bar
What does the symbols mean on the controls
the on off switch has a o and a I The o is off and the other is on
as for the other three you have a from right to left on the main body full chock the half chock the run prime it 7 times on the primer ball with the full choke on the pull crank cable 3 times then move choke to half choke then pull until it starts if after 10 pulls it doest start out back to full choke and sart again if and when it startes let it rund for about 15 secs on half choke then move to run If after all that and you have done it a few times and it still doesnt start get rid of it as it is a totally rubbish tool I know i had one for 6 m onths used iit 3 times then i bought a stihl.
May 30, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi RLT30HT hard to start, won't tick over
Hi
On the rotochoke scale, between the run and half choke position there is a hole and in it there is a screw. This adjusts the idle. Turn clockwise to speed up, anticlockwise to slow down
Jun 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Tanaka 22" Double Sided 24cc Hedge Trimmer Logo
501 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
matt
matt
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
