Question about Whirlpool WED5300S Electric Dryer
CAN I USE A 250 DEGREE LIMIT INSTEAD OF A THERMAL CUT OFF SWITCH?
  • dougm939 Jul 18, 2009
    THANKS FOR ALL YOUR HELP.........MY EXAUST HOSE WAS PINCHED CLOSED.....NOW THAT I HAVE IT RUNNING I SEE MY TEMP SWITCH WILL NOT CHANGE HEAT SETTING. WHIRLPOOL DOES NOT CARRY THAT PART ANY MORE. ANY THING I CAN DO TO REPLACE IT? DOUG
  • Whirlpool Master
  • 8,220 Answers
Those 250 degree thermostats will fail frequently. That is why they come in the package with the thermal cut off. You can reset the thermal cut off by Slamming it on a hard surface, did you know that? What you need to do is determine the root cause of why that dude keeps blowing. The top 2 reasons that small puppy will blow is a stopped up vent and a stopped up filter housing. You will need to physically remove the filter housing to get it right. Take a look at these repair PIX
Posted on Jul 17, 2009
  • Dan Webster
    Dan Webster Jul 19, 2009
    Strange. That temp switch is not the problem. I have never seen one go bad. The 4 wire tstat that has the small 2 wires on top and the bigger red heater wires that carry the amps is what usually is the probo. Those can be bought cheap.
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
    All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
    The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
    Aug 22, 2011 | Dryers
    Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
    in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
    Jul 20, 2011 | Kenmore Dryers
    No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
    The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
    Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
    Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
    Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
    The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
    Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
    Dryers with lint filter on the front.
    Dryers with lint filter on the top.
    Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
    The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
    Feb 01, 2011 | Dryers
    Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
    The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
    The
    thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
    In case the dryer still doesn't heat up with the
    thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
    Jan 19, 2011 | Roper Dryers
    Dryers tumbles but there is no heat
    Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
    Thermal cut-off blows and high limit thermostat is working with vent clean.Replaced thermal cut-off, high limit thermostat and heating element. Still blows thermal cut-off.
    Any time a thermal cut off blows, it's because the cycling thermostat is bad. When it's bad, the machine cycles off of the thermal cut off rather than the cycling thermostat allowing the dryer to over heat. The thermal cut off is a re-setting safety and is not made to cycle off of. The thermostat you are looking for looks like a high limit thermostat but it cuts power to the element at a lower temp. Around 158 degrees + or - 25 degrees. It's located close to the high limit. It's a normally closed switch that opens on the rise and it will show closed now but the problem with it is that will not open. Replace it and your problem will be solved. Good luck.
    Oct 16, 2009 | Kenmore Dryers
    Fryer will only go to 250 degrees
    Need to calibrate the thermostate,or replace it
    Mar 12, 2009 | Imperial IFS40 Deep Fryer
    Whirlpool Dryer Thermal Cutoff Wiring
    the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
    Feb 20, 2008 | Dryers
    Whirlpool WED5300S Electric Dryer Logo
    126 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
