Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Model No. 7754-EZ Bulb is shattered - leaks Won't pump gas
  • 148 Answers
You'll need to replace the primer bulb (not very difficult) if you know the part number go to ebay and type it in and you should get some hits.
good luck!
Mike
Posted on Jul 18, 2009
I pump the primer bulb but doesn't get any fuel in it .
check the fuel 'pick-up' filter in the tank to be sure it's not clogged or stuck inside where it's not in the fuel mix. check the fuel lines for clogs, debris, or fuel 'shellac-ing'.
if the filter and lines are clear and secure, then check the seating of the fuel bulb. you may have a leak allowing air to be pumped rather than fuel.
Mar 27, 2015 | Troy Bilt Tb70ss Gas Trimmer
First bulb shattered with glass particles replaced and lasted 9 months. next bulb shattered after 4 days. getting expensive. what could be shattering the bulbs. Do I need a ballast or a control board
Need to know the make and model of the microwave. Also what bulb it is. If this a halogen bulb, you must wear rubber gloves to change it. The oil in your skin with cause the bulb to break when it heats up.
Oct 14, 2014 | Philips Mwave 50pl9126d/37 lamp for TV
Tv won't turn on. All three lights flash in sequence power heat then bulb. The bulb appears to be in tact.
I will need the model number of the set in order to assist with the issue as the three lights blinking is an error code which would be different based on which model number TV you have.
Oct 30, 2012 | Hitachi Televison & Video
Pump bulb on craftsman weed blower and no gas pumps into the bulb
If you slacken the screws fuel will leak as you have broken the seal between the carb body and the primer bulb so this is quite normal, behind the bulb is a plate with a red non return valve, if this valve is faulty it will not pump fuel, or if the filter in the tank is part blocked it will not pump fuel
Aug 26, 2012 | Garden
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
Which gas line goes to which connecter on the carb? I disassembled to clean and it's having pressure issues. The tank is filling with pressure and the bulb won't retain enough gas to keep the
The thing to remember is that the primer pulls fuel from the carb into the bulb and dumps back to the tank, it does not push fuel into the carb, connect the fuel line from the tank to the carb connection nearest to the alluminium pump cover held with a single screw, the other one goes to the shorter of the two connections on the back of the primer.
Jul 07, 2012 | Craftsman 25cc Gas Line Trimmer
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
Jun 16, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
The gas bulb won't pop back and gas is leaking somewhere. Where do I check?
The bulb pulls fuel from the carb, so there is either a kink in the hose from the carb to the bulb, or there is a blockage in the fuel filter, or in the carb itself, check the hoses, make sure they have not collapsed, or have become trapped, replace the fuel filter in the tank.
Jul 18, 2011 | Poulan 14" Chainsaw
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Leaks near filter
It may be the drain pump that is leaking, you can open the back panel of the unit and figure out if it is so by checking the drain pump for leakage just when the pump starts to work.
Oct 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
73 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
