SOURCE: Simpson 36P450 Washing Machine continuously
It cant drain if you oulet hose is higher than the water level. Raise your drain hose up above your water level. I was pmel (calibration) in the air force..Love it.Went to school at port huneme (navy) school
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
SOURCE: water keeps running through washing
At what height is your exit hose. It should be approximately 3 feet up from the ground and then into the drain. This is rule one for all washers, it cannot be at floor level - your water will just flow out.
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If
the motor is running, your washer probably has a frozen pump pulley or
a broken pump belt. To check the pulley, remove the pump from the
freely--if it's frozen or stiff--replace it. If the pump belt is broken
or looks quite worn, replace it--but be sure to check the pump pulley
before you change the belt.
If
the motor isn't running, the lid switch may be defective. If so, the
washing machine can't spin and may not function at all. The switch is
inside the washing machine main housing near the door frame. Often you
have to raise or open the top or front of the washing machine to get to
the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The
lid switch may be defective. If it is, the washing machine doesn't
spin. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it.
The
motor coupler may be broken. Many Whirlpool®-manufactured washers use a
small, relatively inexpensive motor coupling. It's plastic and rubber
and is mounted to the shaft of the motor on one side, and to the
transmission on the other. Over time, the coupler wears out and fails.
You may need to replace it.
A
belt may be broken. Many washing machines have one or two belts. If a
belt is broken or badly worn, you need to replace it with a genuine
belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive belts.)
The
clutch may be worn. If your washer is a GE, it may use a clutch to come
up to the proper spin speed. As the clutch wears out, it may prevent
the unit from spinning well or at all. If the clutch is worn, you need
to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
The
drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and
draining, the other. It's possible for a motor to burn out in one
direction and continue to operate in the other. If this happens, you
need to replace the entire motor.
The
spin bearing or basket drive may be worn or seized. These components
allow the inner tub to spin freely inside the outer tub. When this is
the problem, you usually hear a loud sound during the spin cycle. Call
a qualified appliance repair technician.
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Testimonial: "thanks for the tip"
