Flashing green timer light
I have the same problem. I read in the other technical support answer from here that it is the DM and that you will have to replace the capacitor. What ever that means. Please provide any diagram and instruction to do this for I haven't got a clue.
Grreatly appreciate any help.
  • Yeemyster Jul 17, 2009
    model WD 62525
  • Sonny Berry
    Sonny Berry May 11, 2010
    need to know the model number of your TV to help you
  • 8,617 Answers
You can get the C26 DLP DM repair kit at the following link. the kit contains the replacement capacitors and the CD with detailed instructions
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
I have a WS-55859 rear projectio tv and a green light is flashing on and off in the front of the set that says timer under the flashing light. the set will not power on
The DM capacitors need replacement. The WS55859 DM repair kit from www.tvrepairworld.com should solve that issue. The kit contains the capacitors and the CD with instructions.
Oct 21, 2010 | Mitsubishi Televison & Video
Flashing timer
Replace the DM capacitors. The V26 DM repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with instructions.
Jan 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light on TV
change the 4 100uf capacitors on the DM board. You will need the service manual to get the set apart as its technical. But with the service manual and take notes you should be able to repair it. But the service manual for that chassis is mandatory or you will never get the chassis out without alot of trouble. Heres a link where you can get the manual emailed to you.
Mar 20, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WS73713 - Now working - Timer light flashing.
hold menu button for 8 sec and then unplug for 1 minute. then when you plug it back in it will work after 1 minute
Dec 30, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
