Question about Saeco Caffe Charisma Espresso Machine
Flashing red water light and flashing green lights
Hi, we are travelling and don't have our manuals. can you tell us what the flashing lights listed above mean?
    Sergeant:
  • Saeco Expert
  • 223 Answers
You can download it at
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Saeco Parts and Information
www.cerinicoffee.com
Posted on Nov 19, 2007
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Red light flashing fast
The main reason for the Fast flashing red is with the water flow meter.
located at the back part of the machine below the power connector - its functionality can be checked in diagnostic mode .
see attached pictures
its either stuck due to in proper descaling or have corrosion in the connector contact of the flow meter.
You can fined the full service manual at Partsguru
http://www.partsguru.com/user/SERVICE%20MANUAL%20TALEA%20ODEA%20REV.03.pdf
Jul 24, 2013 | Saeco Odea Giro Plus Coffee Maker
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one spot.playstation will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
Hi, I droped my SP-320 yesterday and now i can't turn it on. The red and green light is flashing. What does the flashing lights means? Joe
I have the same problem with flashing red and green light when I tried to turn on my Olympus SP-350.
I don't know what's wrong, so please let me know if you have any clue. I personally did not drop the cam, but someone else might and did not tell me :(
May 25, 2011 | Olympus SP-350 Digital Camera
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
If I want to leave my Saeco Odea Go turned on for a few hours I am not able to make any coffee and I am getting a flashing green light unless I turn off the machine and start it again. What is the problem?...
hi,
when the machine is On for long time ,it going in the STAND BY MODE-green light is flashing slowly.Just press coffe button and wait for a 10 seconds.
When the red light is ON and no flashing it is mean there is no water in the water tank or too much water in the drip tray.
Dec 29, 2017 | Saeco Odea Go
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Saeco Caffe Charisma Espresso Machine Logo
1,042 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
