Question about Sony KP-57WS500 57" Rear Projection Television
Continuous flashing green light - Sony SXRD KDS60A2020 TV
What does it mean when your sony projection tv flashes green continuously, please?
  • 6 Answers
SOURCE: Model Sony SXRD Projection
have to replace the lamp... part xl-5100... it's on the left side of the TV (if you are working from the back of the TV). there is one small screw that secures the door to the television1.gif. once you remove that door,the lamp is righ there with the labels that say pull... rempove this part. you'll likely see the shattered bulb on the inside. replace this part and the TV should be as good as new. you will have to call around to find one in stock though. the cost of the lamp is right around $250.00
this works for 50 in as well
Posted on Dec 26, 2007
ctf1800
  • 4402 Answers
SOURCE: KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Posted on Jan 22, 2008
ctf1800
  • 4402 Answers
ensapp
  • 30 Answers
SOURCE: images on tv are green sony 60 in projection sxrd-
If it's bright green with light lines from side to side the green gun is shorting out. You would need to take the front off and look at the neck of the tubes. See if all three filiments are working. It will be a dim glowing in the neck of each tube. If you have filiment voltage but no red gun you may have bad solder connections on the CRT modules but being it's a Sony it could be a bad green Tube. If the green gun is shorting out call around to TV shops in your area and ask them if they have a Beltron or BNK Picture Tube Rejuvenator. Sometimes the short can be cleared using the right test equipment. Ask them how much they would charge you to shoot the tube if that's your problem. If it's no Red it may be bad solder connections on the CRT modules. I hope this helps.
Posted on Oct 17, 2008
Iconoclast19
  • 18 Answers
SOURCE: Continuous flashing green light
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus. You may have to adjust all three colors to get the picture back.
Posted on Jul 27, 2009
Faulty sony rear projection tv
for a possible answer please provide the Model number as there are several hundred Sony projection models that are different.
Dec 15, 2012 | Televison & Video
Just replaced lamp/housing and now tv turns off after 2 minutes of being on. Green light flashes continually(about 30 sec.) then tv turns back on and the cycle continues. The tv is a sony bravia...
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
Jun 17, 2011 | Sony KDF-50E3000 Television
My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
Sep 30, 2009 | Sony KDS-60A2000 60" HDTV
Fare well. :)
Iconoclast
Jul 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KP-57WS500 57" Rear Projection Television Logo
653 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
