I just checked the manual for mine. Press the temp up/temp down buttons together to reset the light. It will come on again after 250 hrs of operation to remind you to clean your filter.
that light will blink a couple of times when the dryer is first turned on , if it stays on all the time, unplug the machine for 5 minutes and see if it resets
this could be a filter clean just like a fridge when you clean filter it resets that you have changed filter,try cleaning your filter in machine and then turn off and restart washer if this doesnt work in your booklet if can help you reset this button as if you have had a service on machine.hope this helps you.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
There is an access flap below the door on the bottom left. Open the flap turn blue levers, take plastic cover off (there may be a bit of water there). Clean the inside. Problem solved
To RESET the Electronic Filter Check: When the filter check light remains on,it is time to check/clean the HEPA-Type filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter check light turns on,the filter check should be reset at the same time. These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent upon the concentration of contaminates going through the system. High concentrations of contaminates such as dust,pet dander and smoking will reduce the useful performance of the filter. NOTE:The HEPA-Type filters are not washable. Fig.5
My LG dryer “clean filter” light won’t go off and it’s clean. Any suggestions?
