Question about Epson Office Equipment & Supplies
My scanner is not recognized by the scanning software
My Epson Perfection 2450 Photo scanner will no longer "speak" to my computer. I've used this setup (Sager notebook desktop replacement - scanner attached via USB powered hub, Windows XPHE SP3) for several years with no problems. Last month, when I tried to scan a document using Silverfast software, I got the error message that the program could not locate a scanner. Upon checking with My Computer, the scanner was not listed in the peripherals. I of course checked the connections to make sure they were tight (and also checked that the scanner was turned on).
Upon checking with Epson support, as well as Silverfast, I have done the following:
Uninstalled all Epson drivers on the computer, and the downloaded and installed the newest version of the scanner driver;
Disabled the computers webcam (I never use it and the Silverfast tech said sometimes more than one imaging device can cause confusion with the software)
After following the instructions on reconfiguring the driver and scanner, the scanner shows up in My Computer and the Device Manager, but any time I try to use it, I still get the error message that the scanner is not connected, or in use. Has anyone else had this problem? As far as I can remember, I made no changes before trying the initial scan last month.
jackboy
  • 2985 Answers
SOURCE: No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Posted on Jun 14, 2007
zone48
  • 25 Answers
SOURCE: error message
What is your operating system?
If XP, check your device manager to see if the scanner is being recognized by XP.
What is your scanning software?
Try to use another scan program ( a free demo version should work fine.)
Are you using TWAIN or an ISIS driver? If it is a TWAIN driver, then any Photo editing program should be able to connect ( usuallly!?).
Posted on Jul 07, 2008
secretgeek50
  • 57 Answers
SOURCE: windows doesn's recognize camera, device manager says no driver
Hi -
Have you tried another USB port? Sometimes, they can act goofy.
Also be sure your anti-virus isn't blocking any part of the installation.
Here is a link to the Samsung troubleshooting guide for your camera.
You can probably download the most recent driver from that website as well.
Perhaps they have a better or newer version than what came prepackaged
with the camera (just because a camera is a new purchase does not mean
the software it came with is the most updated).
http://tinyurl.com/5zsvwd
I run WinXP home edition, so I am not familiar if there are any differences in the professional version regarding software installation....
Posted on Dec 17, 2008
  • 48 Answers
SOURCE: nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Posted on Apr 04, 2009
Van_Fanel
  • 25 Answers
SOURCE: Computer can't connect to scanner
If you are using Win XP there's another way of testing it with your computer for to check if your scanner is damaged or just a simple
software issue:
Usually for Epson it came with an Application called "Epson Scan"
> with the scanner connected to your Computer try to scan using a diff Application like PhotoShop or MS Paint
> to scan using Paint
Click on Start / All Programs / Accessories ( click and open "Paint" )
> from Paint click on File / and click "From Scanner or Camera" and it will open a scanner wizard., just follow the step by step procedure on how to scan.
note: if you have a diff. imaging devices ( like web cam ) it may ask you which one to use., make sure to select your scanner.
> if it can acquire an image using paint or diff application., there's no issue with the scanner unit.
> if it cannot acquire an image using paint or diff application., your scanner is broken / damaged.
To fix the issue with Epson Scan
> Uninstall "Epson Scan" from Control Panel / Add or Remove Programs / disconnect the scanner unit "USB cable"
> Control Panel / Administrative tools / Services ( look for Windows Image Acquisition < WIA > click on it and restart the service.
> Close all the windows and restart your computer.
Download the Twain Driver from the Epson Website
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88043&prodoid=63070037&infoType=Downloads&platform=Windows
downlad > TWAIN Driver and EPSON Scan Utility v3.12A
epson12526.exe )
note: if you don't have internet you can use the cd that came with scanner...
> after it is installed your computer might restart and then:
> click on Start ( right click on My Computer / left click on Properties ) on the Properties window click on Hardware Tab / Device Manager / on the device manager window look for "Imaging"
under Imaging look for your scanner ( right click on it and click on update driver., select this time only hit next / select Install the software automatically ( recommended ) hit next and it will update your scanner driver.
> Close all windows and Launch Epson Scan
Posted on Apr 18, 2009
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Hi, and thanks for your help. sad little noises on start up
Hello b3toed - sorry you're having problems; let's see what can be done.
First, there is a transportation lock on the scanner. (If you have a manual, it will tell you more about this.) Make sure it is unlocked.
Second, test the connection between the scanner and your computer -- make sure it's snug (well connected).
Third, if you were scanning a transparency just before this happened, make sure you've removed the reflective document mat.
After checking these things, turn it off - pause - then turn it back on. Best wishes for good results! -- ambssdor --
Jan 14, 2010 | Epson Perfection 2450 Photo Flatbed...
How open case to Epson Perfection 2450?
go to Epson.com tghey should have the solution if not email me at mike.athome@vodafone.co.nz
Feb 05, 2009 | Apple Epson Perfection 2450 Photo Flatbed...
250 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
