Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
FDB768GCC0 model Frigidaire Gallery series Dishwasher
This model is about 11 years old. It just recently quit working. When the door is closed and the latch placed in the lock position, the power light comes on but nothing else happens. I removed the front panel just to see what I could see. All wires appear to be connected properly. Any ideas? I'm stumped!!
    Genius:
  • 1,003 Answers
REPLACE TIMER
Posted on Jan 18, 2008
I have a fridgaire gallery dishwasher. It is only 2 years old. I have an error code of CL on the display. How can I fix this
check the seal around the door. wipe clean with a towel and then firmly close door and listen for the click. cl means the door is not closed all the way
Jan 03, 2017 | Frigidaire Dishwashers
How can I get my Frigidaire Dishwasher 900 series to start?
Sounds like you have a bad door switch. You might also have a motor that tends to freeze or lock up. It could possibly be a bad motor capacitor too. Does this help?
Mar 18, 2015 | Frigidaire Gallery Dishwashers
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
Frigidaire gallery prof series dishwasher- arms dont work
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher won't start up
this could be a problem at the electrical hook up ,also could be a open door switch or if there is 115 volts to the control board and nothing happening then you need a board.
Nov 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
736 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
