Question about Nokia 6280 Cellular Phone
Hi, my phone is stuck in headset mode, I have turned it off and on several times but it still is. How do I turn it off pls?!?
Is a Plantronics 220 headset compatible with a LG800G phone?
Try to put your headset in pairing mode, prior to trying to pair it with your phone. To do it, begin with it turned off. Then, if it is the first time it is being paired ever, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the turning on phase (a total of some 8 to 10 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. By the way, if its data sheet happens to be missing, feel free to download it from this location.
Really hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further .
Regards,
Carlos
Aug 19, 2012 | Plantronics Explorer 220 Bluetooth Headset...
Would like to know how to turn headset back off...
hi :) wanna ask your phone has water damage right ?? ok,if some water has been remain at the area of charging or headset port,will make your phone show in headset mode,when i n headset mode,that why u cant hear people talking.but once u plug in headset,i sure u can hearing.it cant be solve even how many time u turn on and off your phone. what to do ?? u should send for technician open up your phone to clean up inside.
if my solution useful,please give me rank. thanks.
Jul 19, 2010 | Pantech Matrix Cell Phone
My LG Voyager stuck on headset mode
Turn your phone off and remove the battery. Also tap the headset port (where a headset would normally plug into).
When you reboot it back up it should fix itself. If it doesn't you have a hardware problem (its physically broken) you can see if its under its 1 yr warranty to get your free replacement, or if its older - there's always cell phone insurance.
Oct 28, 2009 | LG VOYAGER VX10000 Cellular Phone
Nokia 6085 is stuck on headset-mode. How can I
try this: get a headset connect it then disconnect it go to settings - profiles - and select another profile. If it doesnt work try to restore factory settings if you dont know the sercurity code it should be 12345 by default
NB: pls vote
Oct 24, 2009 | Nokia 6085 Cellular Phone
Iphone 2G stuck in headset mode= no sound
pls see the contact where the head set plugs in do u see rusty contacts otherwise u can change the headset socket or see it inside for rust for the schematics to dis assemble iphone 2 G see this video PLS RATE ME FIXYA for help
Video for Dis Assembly of IPHONE
http://www.youtube.com/watch?v=X1z0pw2VK7M&eurl=http%3A%2F%2Fwww.gethightech.com%2FMerchant2%2Fmerchant.mvc%3FScreen%3DPROD%26Product_Code%3DIP-2085%26Category_Code%3DIPHONE&feature=player_embedded
may be u need this part for ur IPHONE
http://www.bizrate.com/cell-phone-accessories/oid943283040.html
Apr 17, 2009 | Apple iPhone Smartphone
My lg u8330 is stuck in headset mode and wont turn off
Dear,
turn off ur phone by removing battery and turn it on again and then change the mode of it.
regards,
dont forget to rate it as it will fix the issue
Feb 21, 2009 | Cell Phones
Settin up bluetooth
Turn headset off.
Hold down the "phone" button on the headset.
Turn headset on.
Release "phone" button.
LED ring should be alternately flashing red/blue.
Voila.
Jun 21, 2008 | Plantronics Pulsar 590A Wireless Headset
Password
Hi To Pair the Phone, while the headset is off, press and hold the Volume button until the headset indicator light shines steadily. Open the folding microphone while the light shines steadily. Set your phone to look for the headset by turning on the bluetoth and starting discovery mode. After your phone finds the device and you accept the pair with the headset enter the password 0000 The headset light should flash several times to indicate the pair. Whala you should be up and running. If you need more help re post or email me hartmansp@inbox.com This link will take you to a awesome tutorial with pictures if you need it:: http://www.motorola.com/mdirect/demos/headsets/index.html
May 07, 2007 | Motorola Mobility HS805 Consumer Headset
Nokia 6280 Cellular Phone Logo
155 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
