Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
MY HOOVER BAGLESS TWIN CHANMBER VACUME UPRIGHT THROUGH DIRT OUT THE BACK AND SIDES AS IT IS CLEANING. i CLEANED THE FILTER AND THE CHAMBER BUT IT STILL DOES IT.
  • 97 Answers
Try lowering it to a lower setting. also make sure you change your belts on average every 6 months
Posted on Jul 19, 2009
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
No suction
OK - Details details details.....
If the motor turns on and only sucks a little bit or you are experiencing a great loss of suction,.
THEN
You have a plug somewhere
Be it a partial block from say a HEPA Filter
or else it is a block in the path of travel where items get sucked up into your vacume.
If you look back to the last time someone used it, was it a fine powder which was cleaned up? then look to the filter (see owners manual for maintenance and or cleaning of the vacume machine) Otherwise is it possible that someone else used it and get it clogged with something larger? Although I'm thinking it is the HEPA filter needing cleaning...
The good news is that if the machine turns on, then you know you have a block somewhere in it, bottom line is you will need to find the clog and you'll be back up and running in no time.
Best regards
Ck
Jan 05, 2011 | Hoover Elite Rewind Bagless Upright...
Vac runs for about 15 mins. then stops
The unit is not getting the proper airflow and the motor is overheating to shut down.
You should check/clean out the filter in the dirt chamber there. If the filter is more than 1 year old, you should replace the filter.
Nov 06, 2010 | Hoover U5753-900 WindTunnel Bagless...
How do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Sep 23, 2009 | Hoover U5507900 Elite Rewind Bagless...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Getting no suction
Check the hose for a clog, when suction is low, you will usually find a clog in the hose or in the dirt inlet by the brush roll. If this is less then a year old, then it is still in warranty, if you can't figure it out, then take it and proof of purchase to a warranty repair shop.
Mar 21, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
281 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
