Question about Refrigerators
Ice machine wont dump ice on sears kenmore side by
My repair tech came three days ago and had to readjust defrost timer.. Freezer had frost build up on fridge side not cold... Been three days now ice machine has ice cubes in it but NOTHING ELSE IS FROZEN. and fridge is still not cold enough...Also I did notice Ice machine wont dump ice there are ice cubes in the tray but not coming out. I am at my wits end have been calling the tech 3 days now and he hasn't called us back!!! Could the ice be causing the problem or is themostat set not right or universal defrost timer set wrong he said he set it to 35 minute intervals. Please help
  • 1 more comment
  • lismarmis Jul 22, 2009
    Well I got jack by that guy.. I went and bought a new defrost timer. Kid put one in 110 v 1/3hp max 10 amp defrost timer when mine calls specifically for 1/2 hp 15 amp. He also said he took off the coil to defrost it. I am wondering if it needs freon charge. Also the jerk charged me $145 for the timer he got from sid harveys when I called to inquire the part was on 26.88 my cost. He gave me a receipt from sid harvey stating part only was $145.00!!
  • lismarmis Jul 23, 2009
    I agree... I don't even know if he did indeed take off the coil as he said.. If he did freon must have escaped.. He didn't say anything like he recharged it.
    Time to file a complaint with the AG office. Plus letting my boss know (since he referred to this guy) not to use him or his company!
    PS just wondering can you use a 1/3hp max 10 amp defrost timer in a refrigerator that calls for a 1/2 hp max 15 amp timer???
    Oh yeah defrost heater works fine, put in a new defrost timer.. Wondering maybe he put in wrong thermostat or maybe it could be defrost thermostat is bad. Defrost heater kicked on as soon as I put in model specific one. But stupid thing is freezing up again.. Low freon?? or wrong thermostat or bad defrost thermostat??
  • Refrigerators Master
  • 8,220 Answers
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
Posted on Jul 17, 2009
  • Dan Webster
    Dan Webster Jul 23, 2009
    Greed is a serious sin.
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Is there a simple fix for my fridge/freezer to get rid of frost and start making ice again?
Remove the rear panel on the inside rear wall of the freezer. Unplug your machine. This will give you access to the evaporator coil in the unit. Use a hair dryer to defrost any ice or frost build up that you may see on the panel or on the evaporator coil. This frost up issue is known as a defrost issue which is due to either the defrost thermostat, the defrost heater, or the defrost timer or adaptive control in some units having a fault condition. Most of the units that I do repair the issue is caused from the defrost thermostat having a fault condition. You can disconnect both the defrost thermostat and the defrost heater and perform an ohms test on both of these parts in order to find which is your problem area. The thermostat usually will read at about .50ohms and the heater will usually be around 25-28 but I have seen some also test good at 21 as well. If you have any further questions message me back.If both parts test good and you need to know how to test the adaptive control or defrost timer. 85% of the time this issue is due to the thermostat. I await your reply.
Thank you,
Rick
Dec 10, 2011 | Kenmore Side by Side Refrigerator
We have a model 58262 21.7 cu. fit with gal. door storage refrigerator. The problems began a few days ago when the freezer stopped making ice cubes. By today the freezer and the refrigerator ceased...
Defrost unit asap and then turn on. Remove all ice from evaporator and dry off.
If your defrost heater is not working ice will build up and the refrigerator will not cool properly. Just make sure that when you turn the unit on the compressor is running. If not then you might need a start relay/capacitor. Check this site for parts Sears Online In Store Shopping Appliances Clothing More
Sep 12, 2017 | Kenmore 58522 Side by Side Refrigerator
I have a kenmore side by side refrigerator. the
Hi, Is there ice/frost build up at the rear inside of the freezer?. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Nov 20, 2009 | Kenmore Refrigerators
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Leaking kenmore side byside Refridgerator . It seems to leakout the freezer door side. Ice builds up at the bottom or floor of the freezer.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model when ice is gone take back cover off find drain hole and clean
Aug 14, 2009 | Refrigerators
I have a 4 year old Kenmore top freezer refrigerator. the defrost function is malfunctioning. the freezer frosts up, clogs the air vents, the fan runs nonstop, and everything melts. I've turned off the...
Should be covered alright. Sounds like the defrost therostat is open. Is you defrost heater coming on. It doesn't seam like it is. As you frig runs it's cycle it will turn off the compressor every hour or so and the timer will turn on the heater in your freezer to defrost. Do you feel this heater coming on. If you therostate mounted on the defrost ellement fails to close then your heater will not come on and ice will build up in you freezer. These thermostates seam to be failing more and more these days. I've replaced mine 3 times over the last few years.
Jul 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice builds up on evaporator coils. After chipping off the ice, refrigerator is cold again. This lasts only a few weeks as ice builds up. Eventually, the freezer is cold but the refrigerator is very warmer....
Assuming this was originally a frost-free model, either the defrost cycle timer died or the defrost heating element died. If it's the timer, you might be able to manually start and end a defrost cycle every few days. If it's the heating element, you may be stuck with what you're doing or an expensive repair or buying a new refridgerator.
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Oct 10, 2007 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
238 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
