Question about Microsoft Xbox 360 Console
NO PICTURE XBOX 360 YOU CAN HEAR THE SOUNDS BUT CAN'T SEE THE PICTURE.BROUGHT NEW AV CABLES AND IT STILL WON'T WORK
    Filmmaker:
    Uploaded 5 video answers.
  • 36 Answers
First check to see if the game is running at 50 or 60 pal make sure its the same on your xbox or try turning off your console take out the game turn it back on with the guide button the hold right trigger and y this will reset the display settings on your console
Posted on Jul 20, 2009
Why doesn't my XBox 360 show a picture on the tv
Most likely a damaged AV output socket , possibly lifting of the solder joins,
Jun 11, 2014 | Microsoft Xbox 360 Console
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
We turn the tv and xbox on but there is no picture. We can hear the xbox power up and the tv works otherwise, but no visual for games.
is there sound? check the connections in the back of the tv. if you get red lights on the xbox, then it means a cable is loose some where. check the av swith on the av cord connected to the 360.
Sep 29, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
No picture...
I would try some of these troubleshooting steps;
  1. Make sure that the AV cables are 100% secure.
  2. Try an new AV cable.
  3. Try your console on a different TV.
  4. Call xbox customer support at 18004MYXBOX
May 31, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
114 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
