Question about Saeco Classico Espresso Machine
My Saeco Classico won't brew
Well it was working pretty well but all of a sudden it won't brew. Steamer seems to be working fine. I think it doesn't sound as loud as it has in the past although the steamers seems to be working fine. I did take the screws off the portafilter to make sure that wasn't the problem but that seems fine. When I place coffee or nothing in the portafilter, nothing comes out which makes me think the motor or whatever it is isns't running as strong as before. Any ideas? I have had the machine for at least 4 years if not a few more.
  • cynthia_fren Jul 18, 2009
    Thanks for responding. Water comes out without the portafilter and I can froth just fine. I have descaled recently. When I removed the portafilter after trying to use it, there is water in it. Could that be the portafiler? I really appreciate your help. Regular coffee is just not the same:)
  • bansheracer May 11, 2010
    HI If you just push the brew button with out the portafilter in do you get water out of the brew head? Have you ever done a descale on the machine?
    President:
  • 1,618 Answers
Have you run a backwash on the group with espresso machine soap?
If no then remove the shower screen in the group and clean (that might be covered with coffee oils).
Posted on Jul 19, 2009
The steamer and heating element not functional
checke the power, if theres no power checke the fuse, if damage replace it
Jan 30, 2011 | Saeco Classico Espresso Machine
Water does not heat
More then likely it's the boiler.
Apr 26, 2010 | Saeco Classico Espresso Machine
The brew unit light is steady on and I cannot get an expresso. The pump and steamer work fine.
HI
Open the door and remove the dredge drawer, then the brew unit. Slide the brew unit back in , then push on the upper left side of the brew unit until it clicks. Close the door and push the dredge drawer back in with 1 finger on the right side of the dredge drawer. See if that worked. If it did, then loosen the nut behind the coffee dispenser to release tension on the brew group, then tighten again. Lube the receiver tip on the brew unit.
Nov 11, 2009 | Saeco Magic De Luxe Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Jan 20, 2009 | Saeco Classico Espresso Machine
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
No Water Flow/No Water Draw
Sorry for not responding to you request, but I was not receiving any emails from Fixya.
You can contact me directly if you still need help with your espresso machine.
johnny@CeriniCoffee.com
Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 26, 2008 | Saeco Classico Espresso Machine
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Water Too Hot, Coffee Too Watery
Sounds like there is something wrong with the machine. Could be the thermostats or maybe something like an internal leak that is causing the machine to overheat. It sounds to me like you need someone to take a look at it..
We service saeco espresso machine and are stationed out of New York..
If you need parts of cleaning supplies check out our website:
Jan 01, 2008 | Saeco Classico Espresso Machine
Saeco Classico Espresso Machine Logo
314 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
