Question about Dell 1470 (W9284) 802.11a/g/b Wireless Adapter
Wireless signal degredation
I recently noticed a drastic reduction in my wireless signal strength. I have used my laptop and linksys router for months without a problem. Now out of nowhere my signal is low, very low, or none. I have not introduced any new gadgets that might interfere, checked with my ISP and did a troubleshoot with Linksys.
Additionally, I see that my Dell Truemobile 1150 Series Wireless LAN Mini PCI card is only picking up my home network and none of the other networks I used to see which makes me think something may have happened with the card.
Any suggestions are appreciated.
  • tcylinder Nov 19, 2007
    Thanks Osborne382. I've done everything you mention except uninstalling and reinstalling the wireless card. Do you mean I should physically uninstall the wireless card or use the hardware uninstall function in control panel?
    The closer I get to the access point, the better the signal gets so the card still seems to be "good".
    I'm going to buy a longer ethernet cable and try to reposition the router in a more central place as well.
    Thanks again.
    Sergeant:
    Champion:
  • 306 Answers
Disable and renable wireless card, even try unistalling the wireless card and reinstall it. update driver for wireless card. then if those fail, put pc next to router if signal still bad then card needs replaced. If your ISP didnt have you power off the router for 30 sec then do so.
Posted on Nov 18, 2007
  • cory casper
    cory casper Nov 19, 2007
    from the controll panel.....if the card is a removeable card that plugs into the pc externally...remove it then unistall then connect and reinstall.
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
I have had a LinkSys WAP54G wireless router for 1 month The signal strength has always indicated very low. Is there anything I should /could do to improve this. Interestingly the other wireless...
HI, If its a Internet link which u are speaking about, Please connect the LAN to the System with LAN wire and check the speed. the Problem will be due to low connectivity issue. Wireless router will not increase the bandwidth, it can able to provide the same or below the bandwidth which it received from the ISP.
Mar 01, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
I have a Linksys WRT54g which worked beautifully for 10months. I have an ethernet connection and used it for my PC and a laptop. Now it logs on and off every couple of secs. I tried resetting the whole...
If you disconnect the router , you are able to go online. Go to the Linksys web site. www.linksys.com/download and download the Firmware of the router.
You will need to select the correct model number and the version number of the router.
The model n umber and Version number will be on the back side of the router. You will see model number in small letters like WRT54G and just after that you will see V 5 or V6 or V8. this number will be the version number.
Download the file on the computer.
connect the computer and the modem to the router again and open the router set up. Upgrade the firmware.
Click Here to know more about how to upgrade the Firmware.
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
How do I increase the IP range in a Linksys WRT150N?
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from concrete walls and/or raise it higher to improve the signal strength.
Sep 26, 2009 | Linksys Wireless-N WRT150N Router
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
Feb 27, 2009 | Linksys Wireless-G Broadband Router
Range is very poor
You need to change the wireless channel of the router. Access the router's setup page through http://192.168.1.1, no username, password is admin. Go to wireless tab, Select Manual Setup, change the Radio band from auto to Wide Range. Also change the Wireless network name to a different name then click on save settings at the bottom. Power cycle the router, unplug it for about 30 sec then plug it back in.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Would a neighbors linksys router interfere with my belkin connection?
do check the signal strength of the wireless connection..you can improve signal by removing any big objects between the compu and the router/access point and/or re positioning the router.also intervening walls will affect signal..the fact that you are getting a linksys signal impilies that your home network signal is weak..hope it helps!
Oct 29, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless connection to lap top
try opening network connections disable the default connection and enable linksystems
Jul 13, 2008 | Linksys Wireless-G WRT54G Router
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Dell 1470 (W9284) 802.11a/g/b Wireless Adapter Logo
290 people viewed this question
Alun Cox
