Question about Karcher Garden
Water keeps popping off t he detergent cap.. even though water is not even hook up.. guess it is detergent popping out .. what is wrong with it.. cleaning fitting is not even on
  • 47 Answers
Detergent non return valve stuck, allowing water to back feed into the chemical tank.
depends on what machine it is as to where the non return valve is.
Posted on Jul 18, 2009
Aquarius WML520 Cold Wash not working
Washing machines start a cold wash cycle with hot water to dissolve detergent.
May 19, 2016 | Washing Machines
CAn I use a Zanussi S218t washer with cold inlet only?
You could cap off the hot side on the washer, but will this old washer (20+ years according to the model number) wash efficiently even with the new "biological detergents" (available in the UK, I have never seen it in the US) Apparently in some countries it's common to sell a unit that has an internal heater (not this old girl though) so standard washing detergents will work. You might look for one of these "cold fill only" units or the biological detergent that works at 40 degrees (I'm assuming that is metric, not standard measure, as it would make no sense to have to chill water to that temperature just to have soap work! I don't know why they insist on using that horrible metric stuff everywhere except the US.
Oct 26, 2014 | Washing Machines
What soap do you use to clean a Waterpik SWI 615 Sinusense Water Pulsator?
All detergents are basically sodium laurel sulphate or sodium loreth sulphate. Even toothpaste, hand soap, bar soap, laundry soap, dish soap contains this ingredient.
It allows oils to mix with water by reducing the surface tension so as to make the water molecules (packets) smaller. By doing so the molecules can get at and dissolve oils where it could not get to previously.
Water is already the worlds greatest universal solvent (every element on the periodic table has been found dissolved in water). Sodium laurel sulphate is toxic though and should never be in the human body and perhaps should never even touch the skin as it might be adsorbed.
It makes you wonder about toothpaste. No wonder they give instructions for children's use to not use more than the size of a pea. They suggest to rinse thoroughly. Detergents don't kill bacteria. They just help wash them away. Detergent washes any food that the bacteria may eat.
Keeping an item dry is the best way to kill bacteria. Antibacteria soaps will just help create a super bacteria or super virus. It will just make things worse over time.
Basically use any detergent... rinse well... keep it dry, and avoid the antibacteria soaps.
Jul 27, 2013 | Waterpik SWI 615 Sinusense Water Pulsator...
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
Ul keeps coming up i saw solutions about popping off cap but my carbrio doesnt have a cap
The UL means UNBALANCED LOAD
The washer tries to balance the load automatically as soon as it has detected its off balance and the tub is wobbling. IF you find that the load isnt unbalanced and it keeps coming up(try a load without any clothing) the control board would need to be replaced.
Of course though try seeing if the legs need to be adjusted to level the washer.
Good luck,i hope i have helped you to undestand what is wrong with your washer,
Gene
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
Too many suds even after running the rinse cycle while empty of any clothes
Some of these new top loaders require Frontloader detergent.I know F&P Aquasmart does.if you are useing Topload detergent it maybe over sudsing.Even though its a top loader some of them are ment to use Front load detergent..Fill with water & flush several times.check your book for type of detergent to use or ring & ask F&P.
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washing machine keeps blinking sud what does this mean? It won't finish the cycle.. it is a kenmore front loader HE 5t
Either you have too much of the correct detergent in there or the wrong detergent in there. Here are a few of the errors:
1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.
7)Cold water does not enter washer: hoses connected backwards. Oops.
8)Oversudsing: Wrong Detergent, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. Remove detergent, retry
9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
10)Water heating error, hE, the thermister/heater is out.
Feb 01, 2010 | Washing Machines
Bosch 300 Nexxt won't use detergent on cold cycles
Make absolutely sure you have the hoses connected to the correct inlet valves,it sounds to me as though they are the wrong way round.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Suds in the floor...
are you using he detergent,,,or low suddsing detergent,,,i believe your putting to much detergent,,and not the right detergent,,,to test run a load with no soap,,and see if you get water on the floor..onthejob
Dec 29, 2008 | GE WBVH6240F Front Load Washer
Garden Logo
159 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
