Question about Samsung SyncMaster 753S 17" CRT Monitor
RED COLOR IS OFF. ONLY BLUE AND YELLOW. TRIED DEGAUSS ETC.
  • Harvey Morrow
    Harvey Morrow May 11, 2010
    Do you mean blue and green?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 80 Answers
Was there any sort of magnet around the monitor this ofter causes color problems with some monitors.check you cable that connects the monitor to you conputer if it is bent.
Posted on Jul 17, 2009
Magnet came in contact blue green and red color
Every time you turn on a color TV, a degaussing circuit tries to neutralize magnetic fields on the picture tube face that can cause distorted colors. That degaussing circuit isn't strong enough to clear up the field left by direct contact with a magnet. You need an external degaussing ring to clear up the funny colors. You can see what one looks like here. You might be able to find one for sale on eBay or borrow one from someone in the TV service business. Or you can take the TV to a shop where they can degauss it for you for a small charge. Just be aware there's a chance the picture tube may have been damaged if the magnet was very strong and was in contact with the tube for any length of time. A thin metal screen called the shadow mask is behind the tube face, and if that was warped by the magnet then the colors will never line up correctly again. If this has happened, even after degaussing the colors will still be wrong. But you won't know until you try. Good luck, and thanks for using Fixya!
Jun 02, 2011 | Daewoo DTQ-27S5FC 27" TV
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Problem with picture color
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 26, 2009 | RCA F27TF720 27" TV
Colors inverted, red is green, etc
Disconnect degaussing coil,replace thermister and degauss set with degaussing coil.
Sep 05, 2009 | Televison & Video
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
LG 700B color problem
there isent realy anything you can do about this if im understanding this right i beleave the color tube might be toast.
Sep 13, 2008 | LG Studioworks 700B (White) 17 in.CRT...
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
GE 46GW948 42" flat Screen
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put off tv for 15 minutes & then put on again. do not move when it is on. please let me know if it gets ok or call tech to degauss it . it is hardly 5 minutes job. good luck
Oct 02, 2007 | GE 31GT660 TV
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
No blue screen
what you are describing is a degaussing problem. It normally occurs if some Magnetic source has been brought close to your TV. Perhaps you have shifted your TV from part of the room to another? Or to another room? Did you or someone place a magnetic source (Speakers, Tape recorder, Walkie talkie, some toy of your children, etc near or on top of the TV? Just remove it. And wait for a few days. The problem will get automatically cleared up, as the TV set's Auto Degaussing circuits will clear the color patches.
Aug 18, 2007 | Samsung TSL2795HF 27" TV
Samsung SyncMaster 753S 17" CRT Monitor Logo
199 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
