Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
On the Dell 2405FPW, is the USB CABLE a special cable?
  • joel214 Jul 18, 2009
    IF YOU don't know what you are talking about, please do not comment. the monitor has USB ports on the left side and Dell calls for usb to usb. I ordered usb a2a.
  • 64 Answers
That isn't a USB cable. The cable you're talking about is an HDMI cable that is used for high quality graphics cards.
Posted on Jul 18, 2009
DELL MONITOR 2405FPW,HOW TO ADD TO MY DEVIVCES
Try to use another power cable, or another power socket .
If won't on, maybe you have problem with the monitor.
Have you pressed the power switch?
Sep 11, 2014 | Dell UltraSharp Computers & Internet
On dell 2405fpw, the screen just went black. Unable to select VGA input. Unable to perform self test.
You need to power cycle your LCD moniter, and then disconnect the display cable of your LCD from your system and see if yor LCD is doing the self test, if that is passing the self test that means there is nothing wrong with your LCD you need to check your system espeacially display adaptor and the drivers, you can also cross check if you have any other monuiter at home.
If your LCD moniter does not pass the self test then it means it has crashed you need to get it repaired or get the new one.
Aug 25, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
I have a dell 2405fpw that has developed a blue vertical translucent line that acts like a filter. It is as though the blue setting is too high in one line(about 2 inches wide)
Try reseating the ribbon cable between the T-CON board and the LCD panel first, this problem can be due to bad T-CON or LCD panel.
It is similar to 2408.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%202408WFP%20Rev%20A02/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
My samtron monitor turned into yellow colour
Sir this usually happens because of Serial cable getting damaged I have been through same problem have took my monitor every where but was no use in the end I thought of changin monitor serial cable and now its working great. So I would recommed you to change serial cable.
Nov 11, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Windows Pro XP will not recognize external floppy drive made by Smartdisc. I was given a Dell C8xx floppy drive, however it requires a special cable connector and not a USB
Check Ebay for the proper cable for the Dell floppy drive. Only a few dollars and plenty of them. All of the floppy cable will work on your C800. Note: the floppy cable is not the same as the CD cable. They do not interchange. You must get a floppy cable.
XP will recognize a USB floppy once XP is installed, but you won't be able to boot from it to install XP since the USB drivers aren't installed until Windows is installed.
Sep 15, 2009 | Dell Computers & Internet
Dell 2405FPW onboard cardreader.....seems to be out to lunch.
You could try blowing out the card slot with compressed air and/or swapping out the USB cable the runs from the monitor to the computer.
Aug 29, 2017 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Photo card reader not working
i had the same problem and it turned out i needed a usb cable in addition to the monitor cable. found a cable on an old printer pluged it in and .... presto... "new hardware found"
Aug 12, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Blue Line
there might be problem with the input cable of monitor .... please verify the cable ... try replacing it and then check... this might solve the problem.....
Nov 17, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
254 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
