Question about Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman mower won't engage in gear - Craftsman 24 Hp 48" Deck Yard Tractor
    Scholar:
  • 138 Answers
Not much information to go on, but we'll try - did this just happen after having a rear flat tire fixed? if so, the square key that links the axle to the wheel fell out, easlily happens if you don't know it's there - OR, the belt is off one of the pulleys - OR, the brake is stuck - OR, the bypass lever [on a hydro] is pulled out or not releasing fully
Posted on Aug 22, 2009
Mower will not shift into gear
Please review my answer to:
Craftsman tractor won go into gear had flat tire got it fixed and...
Oct 08, 2016 | Craftsman Garden
Craftsman 2 mower, 12 HP, 38 inch cut, problem is transmission won't engage ... has a spot that looks like a grease gun fit ... what kind of fluid goes in it as well any suggestions on why it won't...
If this is a manual gearbox there will not be an external grease filler, they are sealed and only need topping up if they have been taken apart, if the drive belt is dragging on the gearbox pulley when the engine is running this will stop it engaging, will it go into gear with the engine stopped?
Apr 14, 2013 | Garden
Riding mower won't go nowhere it's got drive belt on but won't drive
Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
Oct 03, 2012 | Craftsman Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starter motor spins won't engage flywheel on lawn tractor
take it off and see if the gear is broken (you can buy the gear at napa)or did the shaft the gear rides on got a little rusty over the winter
May 11, 2012 | Craftsman Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
257 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
