Question about Dishwashers
There is residual two to three incnhes of water
  • edias Jul 17, 2009
    good service
    good service
    President:
  • 2,777 Answers
Could be a pump problem but more likely there is something plugging the line to the pump. Clean out the sump area and screen. Cellophane and onions have a way of hiding in there and blocking the water drain.
Also, follow the line under the sink from the drain in the washer to make sure it looks like it didn't get tweaked at all.
If that doesn't work Remove the screws from under the counter, and pull the dishwasher out, and make sure your "power is OFF. Remove the "discharge hose" from the drain at your garbage disposal, it may be plugged with food. That is why you have the standing water. Your pump is probably ok. but could be the culprit.
Let me know!
Thanks
Tim
Posted on Jul 17, 2009
My steamer is not steaming. I thought the holes were pulgged up with old water left in steamer. Is there a way to unplug it. I have put boiling water through it.
Try a tank of 1 part white vinegar and 3 parts water and see if that does not clear up the problem. Be sure to follow that with three fills of distilled water to rinse out any residual vinegar or calcium deposits left by using tap water. Many steam appliances are tap water rated, but a gallon of distilled water is about $1.25 and will save you this headache. Don't use plain tap water or mineral drinking water in steam appliances - it's asking for trouble.
Nov 19, 2017 | Coffee Makers & Espresso Machines
Inconsistent leaking coming the back of the washer.
The inlet water valve for the cold water has three connections to it. There are a total of 5 hoses that put water in the machine. These are on the cold water side. Check them for leaks, cracks and tight connections.
Jul 24, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Danby counter top dishwasher leaves residue on dishes
Make sure It's not a soap issue by running a load or three without any detergent.
Jan 11, 2015 | Danby Dishwashers
After a load of dishes goes through a complete cycle they are not very clean and they are all covered in a white, hard residue. we have tried running lime away through it also we have tried three types of...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that there is nothing obstructing the outlet pipe and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 19, 2011 | Dishwashers
It is leaving an enormous amount of white residue on our dishes and is causing all of our metal dishes to come out dark.
The white residue could be from one of two sources.
Detergent Residue:
Using too much detergent or poor circulation of water can leave a white residue on the dishes. If the residue is easily rinsed off with warm water then it is detergent. Use less soap, especially if you pre-rinse the dishes or have soft water. Use a hi temperature wash to help dissolve the soap better.
Hard water deposits:
See this link where I put together some information on this.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 01, 2010 | Whirlpool Dishwashers
Dishes have a powdery residue
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
White residue on dishes after wash
check if the residue are soap or not. residue could be from water tank or water itself.
Nov 01, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
