Question about Brother MFC-7820N Printer
Need the printer MFC 7820 N installed on my computer
  • 62 Answers
Hi and welcome to Fixya!
download the driver and install it ...
http://solutions.brother.com/mfc7820n_all/en_us/
Thanks for using FixYa!
Posted on Jul 18, 2009
Black horizontal line when using the feeder but not the flatbed to copy we have the MFC 7820 All in One
clean the glass, especially the little glass. at left side of you, if using feeder all paper pass it.
if not changed it's mean the lifetime drum is over.
May 11, 2011 | Brother MFC-7820N Laser Printer
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back cover open will not go away ... even though back cover is closed!
This is a common problem with the Brother 7820 printers. If you open the back cover, there is a black tray in front of the fuser roller that falls back. That black tray has an arm on the inside on one side that triggers the back cover open message. try pushing that tray up firmly against the back with the back cover open and see if the message disappears. If it does, try taping folded paper to the rails on inside of the grey back cover. The verital plastic rails are what push the black tray into the printer. By taping the paper on you are adding depth to them which will push the black tray further into the printer. If this doesn't work and you cannot get the message to go away from pushing on the black tray, there may be a problem with the trigger. If this were the case I would replace the printer. You can find the 7820 refurbished for $99 online. Just google 7820 refurb.
Apr 15, 2009 | Brother MFC-7820N Printer
How to clean the paper feed for brother mfc 7820 multiple jams
It's difficult to said just by typing, you better get your printer services person to clean it for you.
Mar 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
I have the Brother MFC-7820, I just purchase a laptop with a Windows Vista. I am unable to use the printer. What do I do?
23/Feb/ 07: Updated the Brother original driver(Full Driver & Software Package) for the following products to fix a driver installation problem: FAX-2820, FAX-2920, DCP-7020, DCP-8060, DCP-8065DN, MFC-7220, MFC-7225N, MFC-7420 ,MFC-7820N, MFC-8460N, MFC-8660DN, MFC-8860DN, MFC-8870DW, MFC-9420C
And here is the link of the updated full driver and software package. After you download this, you should be able to run the MFC 7820 with your new laptop=)
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother 7820 Network setup problem
Spoke to soon. the supplied disc failed working the next day.
I think your problem is your firewall!.
Disable the firewall and see if you can print / start it scanning from the brother control center.
If so you know its a firwall prob.
I gave up on trying to configure Norton to recognise it.
I uninstalled Norton Internet Security and then reinstalled it after making sure the printer was printing and the scanning etc could be started. Working fine so far ( a few hours). I am reasonably confident that this will be ok. If the machine has already communicated with the printer then Norton recognises this and allows it. If however the first time you try is after installing Norton it will block it!
DSKDSK
Mar 29, 2008 | Brother MFC-7820N Laser Printer
Printer goes offline
Set IP of printer manually and make sure AutoIP is off. Printout user settings to ensure.
Dec 11, 2007 | Brother MFC-7820N Printer
Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
Dec 05, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
