Question about Frigidaire Dishwashers
Hard to lock door closed
Frigidaire dish washer 08 or 09 push door at top hard to make it lock
  • 3,230 Answers
Focus on the latch if you can look over the top of the door you should see where the latch actuates try to move it with a screw driver gently or directly under the latch inside of the door. The screw to open this door are probably on the inside if it wont open you'll have to make it open.
Good Luck!!
Thanks
Posted on Jul 17, 2009
Door will not lock unless you push extremely hard to close it
It sounds like the lid is warped or bent sometimes by putting basket on top or laundry detergent. Also sometimes kids sit ontop
Sep 12, 2014 | Washing Machines
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washer MDBH940aww...the door is very hard to closed, it seems that you need to force the door close for the latch to lock.. The plastic door latch mounted on the dish washer is making contact wiith the...
Either someone bent the door by excessive weight on it while open (like a kid standing on it) or something is jammed in the sealing surface.
Jun 01, 2011 | Maytag Dishwashers
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
DOOR HARD TO CLOSE
need your door lock assy replaced
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dr error
DR is a Door open error .. you may have a faulity door lock.. first try to see if it is not closing right.. If all closes good the door lock is not to hard to replace... let me know what you find out?
Aug 30, 2007 | Frigidaire ATF6000ES Front Load Washer
Dishwashers Logo
61 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
