Question about Black & Decker Irons
Hi, I have a new B&D iron model ICR505 which I have used once. I plug it in the socket but I can't get it to turn on. Did I accidentally lock it with one of these buttons? I am not familiar with them yet. Thanks for your answer.
2 Suggested Answers
  • 5 Answers
SOURCE: Yamata Steam iron 8800
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
Posted on Jul 13, 2009
My panasonic NI22AWTXJ iron is not powering
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
Jun 22, 2017 | Panasonic Irons
The plug and wire near the plug on my Rowenta iron gets very hot when I use it
The plug is not making proper contact in the wall socket. Clean the pins with steel wool or pot scourer. Do not use water. If you are using a double adapter remove it as it could be the cause of the poor contact. If the problem persist, try a different wall socket and get a qualified person to fix the faulty wall socket.
Apr 03, 2013 | Rowenta DG5030 Iron
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
I have a 1750 watt Rowenta Professional iron. The cord end accidentally fell into a vat of saltwater that was under the shelf where I store my iron. (The saltwater is for my marine fish tank). Now the...
The residual salt inside will be enough for the GFI to think that there is a short in the iron...
Shoet of takeing the iron completely apart and cleaning everything there is nothing you can do...
heatman101
Aug 23, 2010 | Rowenta Irons
MY Rowenta Superpress 050 iron is not getting hot. Thank you.
The first thing to check is the electric socket outlet the iron is plugged in to.
Plug something in that you know is working o/k ,this will prove whether it is the socket or the iron.
If the socket is o/k then the next thing to check is the plug on the iron.
Undo the plug if it has a removeable cover, and check that the connections are good, and check the fuse if it has one, if you are not sure about the fuse, then change it for one that you know is o/k.
If it is a sealed plug then check the electric cord is not chafed or broken near the plug.
Check the cord at the point where it goes into the iron also.
If you are satisfied that all is o/k then the fault is in the iron.
I do recommend that you proceed no furher, unless you are fully competent with electrics, and know what you are doing.
If you are satisfied that it is faulty.It is usually cheaper to buy a new iron, rather than trying to repair it.
Hope my comments are of help to you.
Cheers.
Barkencoa.
Dec 01, 2009 | Rowenta Irons
Stean escaping around cap
If you need a new sealing plug or parts, since I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Jun 28, 2008 | Rowenta DG-980 Iron
Steam escaping around the cap
If new parts are needed, and I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
ROWENTA IRON
The thermostats gone.
try using it on very cool temprature setting.
See if it lasts longer.
Not worth the trouble of replacing a thermostat.
I,d buy a new Iron.
Mike @ Compurepair.
Feb 22, 2008 | Irons
Irons Logo
213 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
