Question about Mitsubishi VS-50705 50" Rear Projection Television
I have the same problem, but i didt myself
I make concave the image whit the remote control, but i cant turn it back i have a mithsubishi vs-50501-a
  • 147 Answers
Replaced the convergence ics if you have concave triple colored images on the screen.
Posted on Jul 17, 2009
I have a Mitsubishi vs 50501 50. The picture would scramble when turned on and not give a picture unless I bumped it. Now when I turn it on it goes right back off without staying powered up.
there is probably quite a few "dry joints" that needs re soldering in the power supply section.
This should solve your problems rather than buying a new one.
Good luck and Thanks for using fixya.
G.
Jun 14, 2011 | Mitsubishi VS-50501 50" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
HOW DO I ADJUST THE COLOR ON MY MITSUBISHI VS-50501A WITHOUT THE ORIGINAL REMOTE
You can order the remote for your model through www.tvrepairworld.com they can get any remote for any television. and the remotes dont require any programing since theyre designed to operate a specific model number TV.
Jan 06, 2010 | Mitsubishi VS-50501 50" Rear Projection...
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Sep 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
I have a Mitsubishi Rear Projection tv (vs-50705). The picture shows a concave image on the top and bottom of screen and the edges go off the screen. I have red blue and green ghost images on the screen...
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Jun 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-50501 no picture sound works great
Odds are real good that the solder connections on the deflection yokes are bad. Go through the front access panel and with a small mirror look and the back side of the connector on each yoke. The top two pins of each will probably show 'ringed' solder connections.
May 07, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Vs-50501 50inch projection with no picture only sound!
Are there any other symptoms like blinking lights on the front or just no picture? This could be as simple as a few capacitors being bad or something more severe. Can you solder? Do you feel comfortable working inside the set where there are potentially dangerous high voltages present even with the set unplugged? Let me know and we'll work through the diagnostic process and hopfully resolve this.
Thanks,
Dan
Dec 31, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi projection tv
I have a similar problem. I have tried to fix the convergence via the remote and that has not helped. My three colors are separated and the edge of the picture is bent in toward the center. I am going to try a hard reset but i suspect the convergence IC are fried. Since the set is not HD, I will probably replace it if the hard reset does not work.
Nov 22, 2007 | Mitsubishi VS-50501 50" Rear Projection...
TV Board Flashing
High Voltage Transformer, FLYBACK try www.bluestar-online.com
Aug 03, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
