Question about IBM eServer xSeries 206
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
I have a server with windows 2k server installed in a HDD SCSI, but When a SATA drive is attached for data storage purpose, the system not initialize, because the system recognize the SATA drive like a boot disk.
Changing the boot order in the BIOS don't works.
  • fixya_wardc May 11, 2010
    what did you attach the SATA drive to?I can think of only 2 possibilities; (1) USBor (2) adding a SATA controller to the server. - and if so, what device shows up in the bios after you hook up the SATA? a "hack" workaround would be to use an external sata device and mount it after booting windows. __________________I found something similar maybe 12-14 years ago, when I had a SCSI Homemachine, and if I put in an IDE drive it insisted on booting to THAT,and I never solved that. __________Just thought of a "real hack" - and that would be to see if you canfind some kind of multi-boot loader (or install a small linux with one)on the SATA drive, from which you can CHOOSE to boot the SCSI disk.
Not a solution: just a follow up. Did you work this out, as I have the same problem now. For others info: the xseries 206, has 2 sata connections which can be configured as a sata raid. It also has 3 hot pluggable scsi slots. When the sata drives are not connected it boots off the scsi to win server. As soon as the satas are plug in ( 1 or 2, raid or not) it wants to boot off the sata drive. Any help would be great.
Posted on Dec 15, 2010
    Sergeant:
  • 449 Answers
Refer to user's manual how to set the boot order in BIOS.
Posted on Jul 17, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
I had this configuration, and it's just needed to set the boot order correctly in the bios menu. For me, it worked. Now, I got an adaptec 7T sata raid controller, and I have both SCSI raid and Sata raid together (320GB + 1Tera).
Posted on Nov 17, 2011
How to load IBM Xseries 206 from USB
expand the "Hard Drive" option under the Boot Sequence.
Then you should be able to move the USB drive up above as primary hard drive, which then allowes to boot from the USB flash drive.
Sep 24, 2014 | IBM eServer xSeries 206
Boot problem with IBM xseries 306 - SCSI Drive and SATA drive os is on scsi drive and wont boot if sata is installed. how do i force machine to skip sata drive
I think first u disconnect ur all HDD to server. then u enable ur booting HDD or operating HDD...and setup again....
Another way: If u have original windows ..u can use windows recovery disk ...then recover ur missing file(kernel).
Thanks
Dec 21, 2010 | IBM eServer xSeries 306
Steps to configure raid 5 on ibm xseries 232
hi,
which material have you ? : CD
which server ? xseries xxx model type ?
If this is the unique SCSI adapter in your system
or the unique seen, you must:
0) download
90p2772.iso 505,085,952 IBM ServeRAID support CD v6.10
or use what you have.
1) Boot from cd (linux) to configure RAID , before install W2K Server
2) run 23k4684.exe (previous site) in another pc and make a floppy
3) boot from W2k CD and press F6 when proposed
4) insert floppy previously made
5) when OS is installed, or from CD or using 23k4687.exe,
install "IBM ServeRAID Manager", to see activity.
Oct 28, 2010 | IBM eserver xSeries 232 8668
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Jun 28, 2010 | IBM xSeries 226 Server
How to repair server 2003 in IBM 226 server
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
Jan 18, 2010 | IBM xSeries 226 Server
Does 206M supports SATA Drives 500GB as well as
Enter BIOS SETUP, and check the "boot order" (after connecting the SATA drive) -- ensure that the SATA drive is *NOT* the *FIRST* boot-device.
Oct 23, 2009 | IBM eServer xSeries 206
Ibm server xseries 326
It is not detecting the HDD because the windows install does not have the necessary drivers. On the windwos install you must press F6 or F2 I don't remember which one but it prompts you for them to load external drivers fro SCSI or other type of drives, you must download the right drivers for the type of HDD the server has probably fromt eh IBM support website, put them in a floppy and load them from the floppy into the windows install so it recognizes the drives..
Jun 02, 2009 | IBM eserver xSeries 360 8686
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Install windows xp on a IBM xseries 200 8479 computer
You have to download the scsi driver from the ibm site. You'll need a floppy and floppy drive. When you boot with your xp cd to setup press F6 to install driver.
Link to your IBM. Since IBM have different models you have to type it at the provided link.
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/brandmain?brandind=5000008
good luck
Dec 20, 2007 | IBM eserver xSeries 200 8479
IBM eServer xSeries 206 Logo
1,800 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
