Question about Dometic Rooftop RV Air Conditioner
Will 30 amp a/c run on 15 amps - Dometic Rooftop RV Air Conditioner
  • Dometic Master
  • 3,361 Answers
Not without tripping the breaker or overheating the AC.
Posted on Jul 17, 2009
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
Where are the fuses for blinkers
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
I hope this helps :)
May 16, 2011 | 2004 Jeep Grand Cherokee
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
1984 gmc seia pickup need fusebox diagram writing on fusebox unreadable
1- 5 amp
2- 30 amp breaker
3- 20 amp
4- 20amp
5- 20amp
6- 15amp
7- 20 amp
8- 15 amp
9- 25 amp
10- 15 amp
11-10 amp
12-10 amp
13-30 amp breaker
14-25 amp
15- 3 amp
Apr 03, 2010 | GMC Sierra Cars & Trucks
I need a copy of the fuse box underneath the dashboard of a 2004 jeep grand cherokee lorado limited edition
Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
F1 -- -- Spare
F2 -- -- Spare
F13 -- -- Spare
C3 -- -- Spare
Mar 07, 2010 | Car Audio & Video
How long will a 100 amp battery run a 30 motor att 2 speed ?
The Endura 30 draws 30 amps at the highest setting (5), so it'll run 100/30 - 3.33 hours with a fully charged 100AH battery. At setting (4), it only draws 15 amps, so it'll run 100/15 = 6.6 hours. At the lowest setting, it draws 3 amps, and should run 33 hours.
Feb 12, 2010 | Minn Kota Endura 30 Freshwater Transom...
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
Radio fuse/cd changer
Number Fuse Amperage
Rating
Circuits Protected
7 7.5 amp Illumination switches
8 10 amp Right headlamp, fog
lamp system
9 10 amp Autolamps
10 7.5 amp Rear blower, speed
control, GEM system,
brake interlock,
overhead console
11 7.5 amp Warning lamps
12 10 amp Liftgate wiper/washer,
front washer
13 15 amp Brake on/off switch
14 10 amp Anti-lock system
15 7.5 amp Air bag system,
instrument cluster
16 30 amp Wiper run relay
17 15 amp Cigar lighter
18 15 amp A/C system
19 25 amp Ignition coil, PCM
system
20 7.5 amp Radio, power antenna,
GEM system,
anti-theft
21 15 amp Turn/hazard flasher
22 10 amp Turn signals
23 10 amp Rear wiper system
24 10 amp Anti-theft relay
25 7.5 amp Instrument cluster,
GEM system
Nov 11, 2008 | 1997 Mercury Mountaineer
Dometic Rooftop RV Air Conditioner Logo
134 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
