I would check the blend door actuator. If the door is open all the way, one direction, the air blows over the heater core. All the way in the other direction, the air blows over the evaporator. Anywhere in between, a blend of hot and cold for temp control. That explanation is a little simplistic. the info is for ford windstar.
Does the compressor kick in when you turn it on?(if not it could be the a/c switch or the power to it, the a/c clutch wire connection, the clutch itself, or it's low on freon) You should hear the clutch kick in when you turn the a/c on. Low freon will also cause the clutch to not kick in. Remove the low-pressure switch plug and jump it with a piece of electrical wire. If the clutch kicks in, you just need to add some freon. Put the plug back where it was after you remove the jumper wire.
Is the belt on and adjusted to the right tension? If the belt is loose it won't cool as good as it should.
Check the freon in the system with a gage. If it's low, add some to the right amount and see if it cools. If it is overcharged, it will blow hot air, too.
The heater control valve slider should be all the way to the left so hot water isn't allowed to circulate through the heater core which would also make it blow hot air out the a/c ducts.
Good luck, they can be a pain, but with careful, step by step troubleshooting it can be fixed. There is plenty of information about a/c online to help you out. Try googling in: auto ac troubleshooting tips for more info. garcuda
Why would it try to get cold when moving at higher
rpm?
Low Refrigerant
Leaks
Air in System
Dirty Evaporator
HVAC System Doors not switching
Expansion Valve or Orfice issues
Compressor Failing
Condensor dirty & filled with leaves between it &
radiator
& More
often on the vans with rear air the air dor acuator goed bad and can no longer switch from hot to cold. also the swich itself will often go bad. this can be caused by sticky fingers damaging the inside of the switch. sometimes a good cleaning in warm water will fix a sticky switch
first useing a scanner or temp gun check the actual engine temp. if it is hot check for fan opperation, air lock in the cooling system water pump operation I think youll find the prblem to be the fan
It sounds like your rear temp. blend door is malfunctioning. You might could get a known good controller from (ebay,junkyard,craigslist) then plug it in. If this does not fix, it is probably a blend door actuator issue.
Hi, my best advise is to have your air check for freon leaks ,low freon causes the compresor cluth to stop working ,this can cause the air to blow hot .......
