Question about Motorola Mobility RAZR V3
What is wrong with my phone??... it turned off by its self and when i turned it back on the screens blank. it'll come on sometimes but only if its cloesd and when i open it it goes off?!?!?!?!?!?
    Problem Solver:
  • 6 Answers
Its the LCD ribbon connector which is failing - probably due to wear. They can be replaced, search google or ebay.
Posted on Jul 24, 2009
My screen just went blank after I locked it now it wont turn on or charge whats wrong with it?
Have you tried removing the battery? Do this and wait 10 to 15 seconds before putting it back together.
Sep 21, 2014 | Samsung Galaxy Grand Neo I9060 8GB Factory...
Tip
Screen problems on phones
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
on Oct 12, 2010 | Cell Phones
My Nokia 6790 won't turn on, what's wrong with it?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jun 20, 2017 | Nokia 6790 Surge Cell Phone
My screen on my lg phone stopped working and only turned white but then goes back off and then doesnt work what should i do?
Software/Virus:
Flex problem
I hope this helps.
Good luck.
Apr 23, 2011 | Cell Phones
Nokia 3110 white display
whats u r problem
Mar 02, 2011 | Cell Phones
N95 black creen
Software/Virus:
Flex problem
Good luck.
Aug 27, 2010 | Nokia N95 Cellular Phone
Lg km900 blank screen during an incoming call -
There is a little rectangle shape thing next to the lg logo on the top of the fone screen. If this is blocked by screen protector it will cause the phone to blank of during calls. Its a power saver that blanks the phone when its near your face. Try it. Take off the screen protector & make a call. Then place your finger over the little thing & the screen goes blank. Just cut a lil space in the screen protector & that will fix the problem
Jul 15, 2010 | LG KM900 Arena Cell Phone
SGH-U700 Not working at all
ur screen's life has gone....change it...u ll surely find ur phone working!!!!!
Nov 28, 2009 | Samsung SGH-U700 Cellular Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Blank screen appears when turning on
tried reset ?? take backup 1st
Dec 25, 2007 | i-mate JAM Pocket PC
Motorola Mobility RAZR V3 Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
