Question about LG LRBC22544 Bottom Freezer Refrigerator
I have the ER IF code. Let it defrost fot 10 hours and code still comes back. Where is the ice maker fan located????
  • Anonymous Mar 13, 2014
    er IF code ice maker fan, where is it?
    Champion:
  • 363 Answers
There are two fans located behind the lower freezer chest back panel, the fan that is in the far left portion is the ice maker fan
Posted on Jul 19, 2009
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
Showing code of ice Er on door disp.
the error code er if means that the main control board lost a feedback signal from the icing fan motor for over 115 seconds. this fan is located in the rear of the freezer section, on the left side of the fan cover. the fan supplies cold air for the compartment where the icemaker is located. the error code may be cleared by disconnecting power to the refrigerator for about 3 minutes, then plugging the unit back in. the code will be cleared, but may come back if the icing fan does not start running. if the error continues to come back after the power has been reset. there may be ice formed around the fan housing preventing the fan from running. the fan cover can be removed, but is time consuming and difficult. you could just unplug the unit for 24 hours and leave the doors open. this will allow any ice build-up to melt and return the unit to proper operation.
May 17, 2015 | Frigidaire Refrigerators
What is 1F code on kenmore elite refrigerator
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct.
Apr 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite Refrigerator Model 795.77563600. The front digital panel has an error code er if. I understand this means that I have a problem with the ice maker fan. Where is the fan located...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a lg lfx25960sb,it is showing ER IF code on the panel above ice /water door,also not making ice?
ER IF indicates that the ice maker fan is not working. The fan is probably frozen. Remove the fan duct and housing at the back of the freezer and you may be able to defrost the ice in the fan enclosure. It will not defrost sufficiently by turning the freezer off for 2 to 4 hours as LG suggests. The fan may have frozen because of high humidity or because the defrost cycle is not working. If your unit is still under warranty LG should fix it by replacing the fan, duct panel and control board with new ones that have been re-engineered to prevent this problem.
Dec 16, 2009 | LG LFX25960 Bottom Freezer French Door...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er IF code
IF is the Ice Fan failure code.  The fan that sends cold air to the ice maker is frozen.  Unplugging and defrosting does not solve the problem.  Mine was fixed as a warranty item when I complained to LG since I had a similar problem earlier with the refrigerator fan within the warranty period.  The fix consists of replacing the ice maker fan and housing (the new housing has a drain hole to prevent freeze-up), replacing the freezer duct housing (again with design improvements), and a new control board (presumably with new defrost programming).
Jun 05, 2009 | LG LRFC25750 Refrigerator French Door
H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ER FF in display ,DISPLAY IS LOCKED, LOUD NOISE
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
Feb 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MY ICE MAKER WON'T WORK
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG LRBC22544 Bottom Freezer Refrigerator Logo
197 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
