Question about Hobart A200 Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
  • 20 Answers
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Posted on Jul 17, 2009
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
I have a Hobart mixer and need the manual or some info on this specific one Model IS:A120 MLNO:25273 VOLTS:240
240v 12qt mixer... that's pretty unusual.
You'll have to register on this site, but you'll probably find what you're looking for here.
http://www.hobartservice.com/Manuals/
Dec 28, 2009 | Hobart Food Mixers
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Service parts list of hobart mixer a120
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
Jan 20, 2009 | Hobart D300 Stand Mixer
Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Jan 19, 2009 | Hobart A200 Stand Mixer
A-200 mixer oil leak
the trans uses all grease today hobart uses mobil lith aw-2 you can get the seal from any hobart office.
Oct 19, 2008 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Transmission Grease for A120 and D300
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Jun 13, 2008 | Hobart D300 Stand Mixer
Hobart A200 Stand Mixer Logo
786 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
