you need to be more specific on the make and model of the video card, also are you getting the error while running an application or just in your operating system?you need to be more specific on the make and model of the video card, also are you getting the error while running an application or just in your operating system?
You can't post conmments that contain an email address.
Wiring, schematic, electrical diagrams, fuse diag, error codes etc are basic contents of these online books they have here on this website www.reliable-store.com I have attached. Must check it out
Most common indicators are:picture may be dimmer or flickering, or no picture with lamp lite error code flashing, or message on screen indicating lamp needs replaced, lamp 1 year old or older.
Have you tried putting the old video card back in to see if the problem is still happening ?
Video card might be installed correctly or not be compatible or you might not have enough ram installed to cope with new video card.
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred or click start type in event viewer press ENTER if you right click on the error select properties you will see what its related to you might be able work your way through the problem Hope this helps.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
