Question about Dryers
I need to replace the propane gas orifice to natural gas
  • Dryers Master
  • 8,220 Answers
Just get the kit and replace it. The kit has a spring and a plug in it that lowers the .water coluum from 10 to 4.5 psi. Unscrew the gas valve and remove the spring and plug and replace it with the one in the kit. Save the LP kit in case you move.
Posted on Jul 17, 2009
2 Suggested Answers
  • 123 Answers
SOURCE: Converting propane to natural gas
hi there..be advised do not attempt this conversion yourself....legislation requires you have this work carried out by a corgi registered gas engineer who will issue you a certificate for you home insurance......NO CERTIFICATE NO INSURANCE..&..YOU ARE PUTTING YOUR LIFE AND OTHERS AT RISK ..
Sir Galahad
Posted on Aug 24, 2009
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
How do u switch it from natural gas to propane
You can purchase a set of propane gas orifices to swap out for the natural gas orifices that your unit has presently.
Contact a local appliance parts supplier and ask for the propane gas orifices for your specific model.
If you swap them out, you will be good to go.
May 13, 2010 | Magic Chef 31000 Gas Kitchen Range
How do I switch propane to natural gas on the stove
all 6 of the orifices 4 on top and 2 in the oven 1 for bake and 1 for broil have to be changed get the correct orifices the propane orifice opening is smaller and the natural gas opening is larger replace all of those and you are ready
Apr 03, 2010 | Magic Chef 31000 Gas Kitchen Range
Trouble with waterheater
DO NOT USE THIS HEATER UNTIL IT HAS BEEN CHECKED OUT BY A PROFESSIONAL!
Most all gas appliances can use propane or natural gas, but they ship from the factory with orifices for one or the other.
Propane is rated at 11 iwg, natural gas at 7 iwg (where iwg=inches water gauge. 27 iwg=1 psig) (it takes a different regulator spring to handle this small difference in pressure.
A propane orifice will be smaller than a natural gas orifice.
The store that you bought the water heater should know what they sold you, and know if they have a kit to convert the regulator and orifices.
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Dryers Logo
107 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
