Question about Toshiba e-Studio162 Copier
Download mode my copier's displays say download mode ???? is not communicating with computer
My mointor just flashes different colors and won't turn off
If you can find a setting for DDC/DI and turn that OFF, this could solve your problem (it did for me).
Description of the setting is included below, but put simply it allows your monitor to communicate with your computer and make adjustments.
From wiki: The Display Data Channel or DDC is a collection of digital communication protocols between a computer display and a graphics adapter that enables the display to communicate its supporteddisplay modes to the adapter and to enable the computer host to adjust monitor parameters, such as brightness and contrast.
Mar 04, 2013 | Hyundai Electronics W240D LCD Monitor
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
When I connect the printer to PC, and press the scan button, the display says that " downloading applicaitons"..No idea what the printer can download?.. When I try to scan from PC , it says...
Try to disconnect the printer from your computer. Restart your computer. Unplug and replug the printer into the power source to reset it. When the printer turns on, reconnect it your computer. Doing this usually fixes minor communication issues. Try to scan again. If problem continues, it could be a firewall issue. Make sure to allow full access to all Lexmark softwares and printer communication processes in the program rules/permissions for your firewall.
May 10, 2011 | Lexmark X5470 All-In-One InkJet Printer
I just had my computer serviced and cleared of virus. Now computer wont activate to communicate with printer. I've already tried everything suggested by the display. Computer has recognised the printer but...
delete the printer icon from the printer display window and reinstall.
you will need the driver CD that came with the printer if the printer model is not in the Windows printer install list.
Jan 31, 2010 | Dell 924 All-in-One InkJet Printer
I have a Dell924 printer/scanner/copier. There is no communication between printer and computer. I have got a new cable, reinstalled printer, configured the usb port, anything I can think of. I looked at...
The problem could be because of ONE out of FOUR problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 14, 2010 | Dell 924 All-in-One InkJet Printer
Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Apr 09, 2009 | E-Machines eMachines T3830 PC Desktop
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Cannon ir 6000 ver 8
my copier show error for E601.Than i am change hard disk.now display only download mode.i want ir 6000 version 8 flash software. please help me....
Nov 19, 2008 | Office Equipment & Supplies
Cannon ir 6000 download mode problem
my copier not working only display the download mode.
Nov 18, 2008 | Canon imageRUNNER 8500 Copier
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Feb 19, 2008 | OKI C5550N Multifunction Printer - Color...
Toshiba e-Studio162 Copier Logo
143 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
