Question about OKI Electric Industry ML320 Matrix Printer
Okidata 320 error light comes on as soon as powered on, printhead resets, no more movement, paper flags/sensors look ok
    Sergeant:
  • 449 Answers
Try taking self test.
Posted on Jul 17, 2009
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Printhead carriage jam facult is showing. No jam, I tried calling the help line. I still have the printhead error fault.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I've had several paper jams in the last few days. After the third one today, I cleared the jammed paper & I can't get it to reset. I unplugged & re-plugged, etc.
this sounds like the timing sensor has been dislodged or damaged this happens when the paper is pulled out against the natural travel path of the paper. look for a broken off sensor flag or a flag that does not move frreely. if the paper is jamming close to exiting the printer check the fuser sensors for free movement. if its stopping more around the toner check the sensor above where the paper first comes out of the drawer. knowing where it jams would be of great help. hope this helps you
Jul 07, 2010 | Canon ImageClass D660 Copier
Problem with new installed printhead
If I remember the 320, there is a head-gap adjustment that is normally moved for replacement of the head and must be reset again. Check your manual for that term; 'Head gap adjustment'
Aug 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Aug 10, 2009 | HP LaserJet 5200tn Printer
13.20.00 Jam inside top cover
Jun 04, 2009 | HP LaserJet 5200 Printer
Okidata printing problems
It probably needs the shaft that the printhead moves back & forth on cleaned and oiled, or the printhead is overheating, or the ribbon is jamming up (generic ribbons do this a lot !)
If none on the above fix the problem, make a note as to what lights are on steady and flashing and post them. (That is the error code)
Jan 16, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata microline 320- having menu problems
Menu Light flashing is a printhead thermister overheat problem.
Power off the printer and try reseating the print head; if this fails you'll need to replace the print head!
Nov 21, 2008 | Matrix Okidata Microline 320 Printer
OKI Electric Industry ML320 Matrix Printer Logo
102 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
