Question about Kitchen Ranges
For no apparent reason, oven won't light - broiler won't burn either????
  • 19,396 Answers
Ensure that the oven is not locked on self cleaning cycle.
Try tripping circuit breaker or unplugging power cord to reset the oven control.
On some oven you may need to push the control knob after a power surge.
If that does not fix the problem, then the oven may be faulty, in that case a faulty the thermostat, faulty selector switch, or broken wiring can cause the problem.
regards.
Posted on Jul 17, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Whirlpool oven won't light
check the bulb in the oven
or oven light wsitch look more to the bulb
Aug 01, 2012 | Whirlpool Kitchen Ranges
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Changing a broiler element on a Thermador PD366BS-03 dual fueal range.
Maybe this link will help. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/13-115-200411-/Thermador-Oven-broiler-not-working-PRDS484GG
Nov 05, 2017 | Kitchen Ranges
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
