Question about Haier Mechanical Air Conditioner HWF05XC7
When i turn my Air conditioner on high cool i hear it trying to kick in but then the whole power just shuts off even the fuse switch...any answers to what it wrong?????
  • 867 Answers
Just guessing, seems like the compressor is siezing up and blowing the fuses
Posted on Jul 17, 2009
I have a Haier air conditioner model HWR10XC6. It's been in storage since last fall, and I put it in our window this morning. I plugged it in, and the light on the panel came on for a split second,...
First check if the fan is running. If the fan is notrunning is the compressor not running also, if neither is running the possiblereasons are 1, no power to outside unit, 2.bad contactor on outside unit, isthis buzzing if it is this indicates no power, 3 bad capacitor, do bothcompressor and fan humm then quit humming and hum some more, 4 high pressure switchhas shut unit down because fan wasn't running if compressor was running but notfan, if your unit has this there will be a manual reset button where the lines come out ofunit. If compressor was running and fan was not, 1 bad fan or 2 bad capacitor. Please check these followings: 1. Thermostat checks i) Is thesystem selector switch in the "Cool" position?
ii) Is the temperature set at least 3 degrees below current room temperature?
iii) If your thermostat is electronic, are the batteries charged?
iv) Some forced-air furnaces have a switch on the thermostat that allows you toturn the fan on independently of the furnace or air conditioner. This switchwill be marked "ON" and "AUTO". Does your thermostat havesuch a switch?
v) If the answer to the above is Yes, listen for the furnace fan coming on. Ifyou cannot hear the fan, go to one of the supply registers and see if you canfeel any air coming up. Is the furnace fan operating?
If everything seemsfine with the thermostat, the next step is to make sure there is power going tothe furnace.
2. Electrical checks
(A) Items to check at the furnace
i) Your systemmay be equipped with an emergency shut-off switch for the furnace. If so, makesure it is turned ON. In most homes, the emergency shut-off switch looks justlike a regular light switch and will be located close to the furnace. (Tracethe wire from the switch to the furnace to make sure you have the right switch.)It is quite common for this switch to be turned off accidentally. If the switchis ON, but the fan still doesn't operate, proceed to the Items to check at theelectrical panel.
ii) Some heating systems also have emergency cut-out switches that are activatedwhen a door or service panel is removed. Often the furnace door is not replacedproperly after a filter cleaning and the cut-out switch will prevent thefurnace from coming on. Check to make sure all access doors are properlysecured and fitted. (B) Items tocheck at the electrical panel i) Thebreakers for the air conditioner and the furnace should be in the"ON" position. If a breaker has been tripped, it will be in aposition between ON and OFF. To reset, turn the breaker all the way off and thenback on. If you have fuses instead, make sure the fuse hasn't blown. If it has,replace it with the same-d fuse. If you havedetermined that there is power to the furnace but you are still not getting anyheat, select your heating fuel type from the list below and continue with thechecks. If you have discovered that the furnace is not getting any power, callyour service contractor. (C) Items tocheck at the air conditioner i) Somecentral air conditioners are installed with a switch, or electrical disconnect,mounted outside to turn off the main power to the unit. Whether or not you havesuch a switch will depend on the electrical code in your area. If you have adisconnect switch, check to make sure it is in the ON position.
ii) Is the fan running on the unit outside? (If the fan is running, you havepower to the unit.)
iii) Some air conditioners will make a little buzzing sound, even when they arenot running. Have you ever noticed this before? Can you hear it now? Summary: Ifyou have determined that there is power to both the furnace and air conditionerbut you are still not getting any cool air, continue with the checks in thisguide. If either the furnace or air conditioner does not have power, call yourservice contractor. (D) Icechecks i) Is thereice building up on the pipes connecting the furnace to the air conditioningunit outside?
ii)Touch the plenum (this is the sheet metal box that comes off of the furnace;the evaporator coil is inside). Does it feel very cold? If it does, theevaporator coil may be frozen and you'll need to call for service Hope this will help you. Good Luck.
Jul 15, 2011 | Haier hwr10xc6 Air Conditioner
Turn on unit starts blowing cold air for about 5 minutes the compressor kicks off. will not come back on. you can turn it off and back on and compressor will start back up again for about 5...
soulds like when it starts the high pressure switch kicks it out when you turn the power off you equalize the pressures check you coils and filter they need to be cleaned most likely this is the problem
Sep 11, 2010 | Comfort-Aire RAD-243 Air Conditioner
Our frigidaire window a/c unit (model faa067p7a) does not seem to be operating properly. There is no condensate forming anywhere (beneath the coils is dry and no evidence of water and there is no water...
It sounds like your unit is low on freon or the compressor is not kicking in. If the compressor kicks in you can hear it turn the unit on fan only or turn the thermostat off then turn the unit to demand cool you should hear a hum even vibration when the unit kicks in. If there is no audible hum ect... your compressor is probably not kicking in. The selector switch the temp switch the capacitor for the compressor or the compressor its self could be bad. good luck if you need to know how to test any of the above let us know
Aug 11, 2010 | Frigidaire Compact Air Conditioner
Problems with Amana Quiet Zone 12M12TA, kicks off after short runtime, but other times runs for an hour cooling OK. Hear a clicking when it shuts down? Could not find a fuse ot relay?
Does it run longer when it's cooler outside like at night? If it is, it could be shutting down on high pressure or temperature caused by dirty condenser or you could have an overload in the compressor wire box that is weak or has a loose connection. Check the condensor coil to see if its dirty and see if it has an overload on the compressor.
Jul 11, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Jul 20, 2008 | Carrier 38CKC036 Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioners not working just blowing hot air . when u turn it on , u can hear that it want to start, but shortly after it shut down
usually the compressor kicking on and off is an indication that you are low on refrigerant and the low pressure switch is "cycling" the compressor on and off. to verify this, locate the accumulator and/or the low pressure switch, pull the connector loose from the switch, jumper the switch with the motor running and the control calling for high cool, if the compressor kicks in and stays running with the jumper installed you need to "top off" your refrigerant charge. hope this helps
Jul 02, 2008 | 2001 Mitsubishi Montero
Central air conditioner doesn't turn on... Any suggestions?
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation. If your central air conditioner doesn't go on automatically: 1) Be sure the thermostat is set to "cool" and set below room temperature. 2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse. 3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off. 4) Turn off the power to the air conditioner and check the thermostat. 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. 6) Turn the power back on. 7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Haier Mechanical Air Conditioner HWF05XC7 Logo
155 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
